#1181 |
I like to show what is possible today. The pictures are not smoothed. Measurements at the listening position.
Shown is the behaviour of a B&W 801 D speaker before and after optimization by FIR filter with minphase and excessphase correction (filter size 65536 taps). So first: Amplitude response shown Uli |
#1182 |
Second the step response
Uli |
#1183 |
diyAudio Chief Moderator
Nice step response and room modes correction. But why aiming for flat at listening position? Gentle slope is the natural sound in the far-field.
#1184 |
Hi Uli,
Those measurements look impressive. Could you comment a little on how they were taken? e.g. swept sine/MLS? What was the room like? Anechoic? 'Normal' domestic room? Size? Speaker placement? Speaker distance from listening position? Thanks, Matt
Wingfeather |
#1185 | |
There is a slope given in the target curve. So why do you not see it ![]() If you study room correction you will see that all the corrections are typically done by smoothing or averaging the frequency response. Quite often you only see only this response but not the unsmoothed FFT result. You have to know that of course the inversion of an unsmoothed curve is simply not possible (you also do not wnat to get nailed at the listening position). Typical smoothings like e.g. 1/n-octave analysis creates errors, the curve is pulled down by the dips of the unsmoothed response. Thus e.g. with TacT you find even targets with quite steep slopes. In this case a psychoacoustic analysis has been applied. And the target follows the natural behaviour of the result of the analysis which is typically a slope of -3 dB falling at the right side. So the correction as the result of target minus the interpreted measurement is more or less at level zero. At the end this results in the shown curve. And there is nothing wrong when listening. No bright or harsh sound, no nasty digital sound. The unsmoothed response looks more or less flat though. But no problem. Uli |
#1186 | ||||
Uli |
#1187 | |
Do you have a 6th octave smoothed one to post? Good you follow a slope. Thanks for the explanation, because I could not possibly know if it pulls down when you smooth. I am no CPU.
#1188 | |
Hi Uli,
That would be a good impulse response to get if you'd taken it in a very large anechoic chamber, let alone an average untreated room. Did you take any special precautions to minimise room effects?
Wingfeather |
#1189 | |
Anyway you see that the curve does is not influenced by the dips. Also shown is the target (blue). Hope this helps Uli |
#1190 | |
Appended a comparison of pulse response (red) and step response (green) in one picture. You can see that reflections in the pulse response are in a way smoothed by the integration. So it is always necessary to clearly tell what a curve shows. Uli |
| Page generated in 0.14638 seconds (75.40% PHP - 24.60% MySQL) with 11 queries |
