In order to eliminate Cms-based distortion, should Cms be...
Old 31st December 2006, 03:25 AM   #1
454Casull is offline 454Casull  Canada
Default In order to eliminate Cms-based distortion, should Cms be...
constant (flat line vs excursion) or purely parabolic (vertex at 0mm)?
Old 1st January 2007, 02:05 AM   #2
noah katz is offline noah katz  United States
Cms and its inverse the spring stiffness should be constant.
Noah
In order to eliminate Cms-based distortion, should Cms be...Hide this!Advertise here!
new idea? to eliminate need for BSC pforeman Full Range 26 14th June 2009 10:33 PM
Eliminate POP on power off groover1234 Car Audio 21 3rd December 2007 05:06 AM
2nd Order Distortion Circuit lineup Solid State 15 2nd January 2006 08:44 AM
Freeware Program To Eliminate Hum From Wav Files? kelticwizard Everything Else 4 3rd April 2003 03:22 AM
What is worst - even or odd order of distortion DarkOne Solid State 18 8th February 2002 12:42 PM
