If I put a multimeter to the + and - of a driver, what is that impedance rating I am getting? What does it mean in terms of the impedance that driver will have towards my amplifier?
Thanks again! |
#2 |
You cannot use a multimeter/vom to check the impedance accurately of any driver. The only correct way is to use an impedance meter.
#3 |
Assuming you have disconnected the driver from the amp, the ohms you read should be about 25 or 30% lower than the impedance the driver will present when it is playing music.
So an 8 ohm driver will read about 5.8 ohms or so on the multimeter, a 4 ohm driver will read about 3 ohms or so.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#4 |
These are for nominal ratings. The actual impedance will vary according to frequency.
#5 |
diyAudio Moderator Emeritus
Hi patchwork,
The first thing to know is a driver's resistance changes with frequency. So a single figure doesn't tell you everything. You want to view the driver's impedence plot to know what you're amp will really be driving. Re is a driver's DC resistance which is measured with a MM with the driver in free air. The nominal impedence is a kind of average taken from the impedance plot of the driver. Usually means very little.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#6 | |
There are too many variables in trying to use a VOM/multimeter. First and formost how accurate is the meter? I always say the proper tool for the job. This is why we mention the usage of books by Morgan Jones and other people noted for their profound knowledge to school people and provide a proper knowledge base. |
#7 |
Maybe he just wanted to know if he had a 4 ohm or 8 ohm woofer.
#8 |
kelticwizard
My logic is very simple but some may feel it is flawed. In an ideal world you would teach someone how to use the proper tools. It would be very simple for patchwork to drive down to his local stereo shop and borrow an accurate impedance meter. This meter would provide him with all the necessary information he would need to evaluate his current driver. Example: It would provide the impedance at different frequencies. It would also tell him at a glance if there was any voice coil damage to the driver. This is why I push the idea of using this tool which has been designed specifically for this purpose instead of trying to use a VOM meter. I don't care what you factor in for your percentage of impedance it simply will not provide accurate information. Story time now.... I work for a sound consultant in the midwest. My job consists of fixing what people "in the know" screw up. In other words when a sound system (usually a large one like a stadium system) gets screwed up I fix it. I have had my hands full of people trying to use a VOM meter to analyze a speaker load and making changes based on what their VOM meter tells them. It is simply incapable of providing accurate results and therefore shouldn't be used period. |
#9 |
Hi Burned,
is there a diy version (cheap and easy to source/build) that can do the job properly? Can you tell us how to use it after we have built and calibrated it? I have used the Constant current method and it is certainly not simple.
regards Andrew T. |
#10 |
Hi Patch,
you have gone very quiet. Have you got your answer? Or do you want more?
regards Andrew T. |
| Input impedance of tubelab simple se | pforeman | Tubes / Valves | 1 | 24th May 2009 12:42 PM |
| Input impedance of tubelab simple se | pforeman | Full Range | 2 | 24th May 2009 05:10 AM |
| Input impedance for Simple SE? | jrn77478 | Tubes / Valves | 1 | 16th January 2009 04:47 PM |
| a simple question about speaker Impedance?? | Minion | Full Range | 8 | 23rd October 2006 06:08 PM |
| Simple answer required for a simple question... | rabbitz | Multi-Way | 4 | 31st August 2003 10:05 AM |
| Page generated in 0.09767 seconds (79.20% PHP - 20.80% MySQL) with 11 queries |
