Hello,
I am in the middle of assembling the Ed Frias AR.COM kit (I know it is controversial). My first electronics project, period. Two dumb questions: (1) While soldering I accidentally melted a little of the jacket of what I believe is a capacitator (black cylinder labeled 4.70 ufd). I covered up the wound with electrical tape. A little gray metal showing thru. Am I going to be OK? (2) As I lower woofer into cabinet, I'm pretty sure speaker wire from the crossover will brush against the rear of the unit (magnet). Any interference problem? Thanks!! |
#2 | |
The melted plastic jacket on the capacitor is no problem. Covering with electrical tape is fine.
I would relocate the wire. You will probably be annoyed if it starts rubbing and clicking and buzzing against the driver! But it won't be the cause any sort of electrical or magnetic interference or anything of that sort. Quote:
#3 | |
diyAudio Moderator Emeritus
Rodd Yamashita |
#4 | |
#5 |
Thanks for your reply Wodgy,
The melted thing is called a "Solen 4.7mfd Metallized Polypropylene Capacitor, PB Series 400Vdc, jacketed, ""Fast Capacitors""" Not sure if that is electrolytic or film--AB |
| Newbie Sub Questions | demondo | Subwoofers | 17 | 4th June 2007 11:13 AM |
| Newbie Questions | Mjr7531 | Multi-Way | 8 | 20th December 2004 09:18 PM |
| more newbie questions | feralear | Tubes / Valves | 2 | 3rd December 2003 05:30 AM |
| Newbie Questions | BlakeB395 | Tubes / Valves | 1 | 20th June 2003 04:01 AM |
| Page generated in 0.08870 seconds (75.05% PHP - 24.95% MySQL) with 10 queries |
