hi everybody, i've a pair of this devices, Coral electronic RS80, i attached the pdf with the t&s and specs (sorry is in italian...)
now, i want to build a good 2 way bookshelkf speaker system using them... for the tweeters, i think that the RS10 from the same product line will be fine... but i accept suggestions there is also a crossover from the same company.... anyone has suggestions for project this speaker? (box volume) crossover circuit ecc. ecc.... thanks... i attached all the specs for the devices... |
#2 |
the tweeter
#3 |
the first crossover
#4 |
and the second crossover...
i'm waiting for replyes.... |
#5 |
diyAudio Chief Moderator
Do they have a box with both drivers and one of their crossovers mounted so you can listen to? Because from such individual component data and not system data, our guess is as good as yours.
#6 |
Nice driver
Closed 20 liter.... or... 35-40 liter BR, port 50 x 100mm Your tweeter has high Fs, so you will need high crossover point A better tweeter could be the new Peerless HDS The first crossover looks fine but inductor is much too big and it might get you into trouble with the tweeter The second one is a bit simple, but it might be the one to go fore, but it very much depends on woofers top end Or make a hybrid of both |
| Driver suggestions | Marcel_D | Multi-Way | 3 | 19th October 2007 09:41 AM |
| Suggestions for new driver for sub | geoffstgermaine | Subwoofers | 0 | 8th March 2007 03:17 AM |
| Driver Suggestions | renfrey | Full Range | 3 | 7th June 2005 07:13 PM |
| Driver Suggestions | bjackson | Multi-Way | 10 | 28th February 2005 12:23 AM |
| TL sub driver suggestions | slackerbob | Subwoofers | 1 | 23rd October 2003 11:39 AM |
| Page generated in 0.08556 seconds (73.19% PHP - 26.81% MySQL) with 11 queries |
