Hi everyone, just wandering if anyone knows where i can get these in M4 and M5 sizes also may need M3 size. I fould insertsdirect on the web but they want like 100 Britsh pounds just for postage !!!Plus 45 pounds for the inserts(not too bad a price for 1500) I would prefer if there was someone in Australia that sold them, otherwise overseas is ok providedi can get decent price on shipping.Man cant beleive postage is soo much!!
Well here it is. Regards Bowdown
Keep up the DIY spirit!! |
#2 |
start your search using: T-NUT with some luck you will find a usefull link
#3 |
diyAudio Moderator Emeritus
Not in Australia but: http://www.madaboutsound.com/prod.asp?pname=FAS
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#4 |
Hi bowdown. Try the Yellow Pages under fasteners. I suspect in Australia they are called something else. They guys at the local hardware stores just give you funny looks when asking about them.
A friendly furniture maker may point you in the right direction. Regards, Geoff |
#5 |
my local bunnings stocks these in a range of sizes in packs of 4
#6 |
Hey guys thanx for the replies. to audiofan, i tried searching on the net for t-nuts and pretty much anything else i can think of but i dont get any good hits. I will try the other places out that have been suggested. I will post back my findings if i find anything as quite a lot of guys on the forum are always looking for stuff like this. To Wilco, do you remember where they were at your Bunibgs store? i went in yesterday and had a look at the fastener section but could not find any there. Thanx for all your help guys. If anyone does find them though please let me know.
Cheers Bowdown
#7 |
try Parts Express: http://www.partsexpress.com/webpage....ctGroup_ID=829
#8 |
hi bowdown, we use those at work, google the word barb-sert.
#9 |
There is always the third way - Rawl Bolts come in M4 and M5 sizes (you may have a search to find them though, more common is the M6 and M8).
![]() Simply drill the hole for the bolt, smear a thin coat of epoxy on the outside of the bolt (it really wont need much at all, possibly a match head or two), insert the bolt, and expand the fixing (following the instructions). The nut is captive, as long as you followthe instructions for the correct diameter hole... A strong permenant fix, that is less likely to tear out than the barbed fittings (do remember to wet the wood if you use those, it helps the wood deform around the barbs on insert, instead of tearing, and provides enough moisture to re-swell the timber tightly onto the fixing...) Hope this gives some ideas... Alternatively, you could look at plasterboard (Gib) fixings - the in-hole expansion type... bound to be some of those near you Owen |
#10 |
Gib fixings
http://www.powers.com.au/Products/focus.aspx?bgid=66 http://www.powers.com.au/Products/focus.aspx?bgid=32 These are aussie companies, and a good starting point... you should be able to find something similar locally Owen |
| Know where I might find this sub? | Dominick22 | Subwoofers | 1 | 16th August 2006 08:39 PM |
| Where can I find this Pot US? | jealousblues | Parts | 0 | 20th July 2006 04:08 PM |
| Help me find a job | lawbadman | Everything Else | 28 | 14th June 2006 12:30 PM |
| $1 AMP find | dougv | Tubes / Valves | 32 | 6th June 2004 08:03 PM |
| please tell me where to find | kaukasion | Solid State | 3 | 3rd July 2003 09:58 AM |
| Page generated in 0.10989 seconds (77.29% PHP - 22.71% MySQL) with 11 queries |
