Hi all,
I'm realizing my first project and I'm wondering if I shou;d use series inductor, capacitor and resistance to achieve calculated values for a audio crossover ? I'm asking that because it's almost impossible to buy components that have the exact calculated values... Thanks, REALFLEO |
#2 |
1 - you can add capacitors' values by putting them in parallel
2 - you can unwire inductors to match the desired values. Lalena calculator 3 - for resistances place in parallele use the formula R = (R1 x R2) / (R1+R2) |
#3 |
Rounding to within 5% is not unreasonable, even 10% is sometimes OK. If you also consider that calculated values are not always perfect for the job, it makes practical sense to initiate your crossover with the nearest available values, and tweak from there.
#4 |
Can I use inductors in series like capacitor to match calculated values or it's better to take a bigger one an unwire it like u said ?
Thanks, REALFLEO |
#5 | ||
#6 |
Ok thanks for your posts guys
REALFLEO |
#7 |
One of the common concerns with inductors is their DC resistance. In some parts of a crossover this really is not a problem but where it is, this can be a reason for purchasing a quality coil.
If you look at one 1mH inductor alongside two 0m5H's in series, the DCR should be higher for the pair (assuming all three were wound with the same gauge of wire). Therefore, having all the windings on the same form can increase the effect and reduce the wire used. This also means that two 2mH inductors in parallel should have a lower DCR than the 1mH on its own. Of course the problem of cost and of interaction and the inelegance make purchasing a more expensive 1mH to start with the better option. If it helps, I have been known to use much larger values of inexpensive iron cored inductors in parallel in order to tweak values during testing. |
| WTB: Crossover components | TurboFC3S | Swap Meet | 1 | 18th July 2007 06:19 PM |
| Parallel and series components in xover | andy2 | Multi-Way | 7 | 22nd November 2004 04:32 PM |
| BC Components KP460 series... | Luke123 | Solid State | 2 | 29th February 2004 07:42 PM |
| Crossover components: what should I use? | LKS | Multi-Way | 2 | 25th September 2003 01:33 PM |
| Aleph series and components | jejeaudio | Pass Labs | 1 | 26th February 2003 11:55 PM |
| Page generated in 0.08369 seconds (85.37% PHP - 14.63% MySQL) with 10 queries |
