Old 26th December 2006, 10:07 AM   #1
e-side is offline e-side  Netherlands
Default OB, Fequal and effective distance D
After having read the Design Models and FAQ pages on Linkwitz's site and a couple of threads on this forum, I'm still unsure about the effective distance between the front and rear wave in an OB speaker.
According to Linkwitz the frequency at which the output of an OB speaker equals the output of a closed box with the same driver can be calclauted as Fequal = 0.17 v / D
D is the effective distance between the front and rear wave, right? In case of a circular baffle with the driver in the center, does D equal the radius of the baffle (half the width of a rectangular baffle) or the diameter (total width of a rect baffle)?
Maybe I missed something, but here Linkwitz takes the total width ('diameter') of the Phoenix as D, while here half the baffle width ('radius') is used...
Could someone help me with this question?
Erwin
Old 27th December 2006, 02:51 AM   #2
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
D is the extra distance the rear wave must travel, so on a flat circular baffle D is the radius. For example, I've played around a little with 15" drivers with no baffle at all, so the driver itself is the baffle. D=7.5" and Fequal predicted at 306hz. 15's don't display the 6db peak above Fequal because Linkwitz's stuff assumes a center point of origin, but a 15 launches it's wave from a wide range of surface to edge distance, so the response was surprisingly smooth. It just starts rolling off at 6db/oct at about 300hz. Smaller drivers don't fair as well with circular baffles.
Everyone has a photographic memory. It's just that most are out of film.
Old 27th December 2006, 03:51 AM   #3
Davey is offline Davey  United States
Erwin,
It can get a bit confusing, but the first case you noted is for the Phoenix woofer which is more complicated than a simple flat baffle.
SL explains it much better on this page..IMHO:
http://www.linkwitzlab.com/models.htm#B
Davey.
Effective mass?? dario54 Analogue Source 6 6th August 2008 07:40 PM
effective mass IZHAKKATZ Analogue Source 6 6th August 2007 08:48 AM
What's the effective delay ? Will Multi-Way 8 26th March 2006 06:45 AM
diysubwoofers.org - effective diameter from Sd Dave Jones Multi-Way 4 31st May 2004 12:21 PM
effective mass peterr Analogue Source 9 5th April 2002 02:52 PM
Page generated in 0.06549 seconds (79.30% PHP - 20.70% MySQL) with 10 queries
