Sealed vs Ported (Rythmik) - diyAudio
Old 24th December 2006, 08:01 PM   #1
Default Sealed vs Ported (Rythmik)
Pardon if I was unable to locate a thread answering my particular questions, but I am unable to locate the best answer.
I am looking at building a Rythmik Audio Servo Sub, a 12" sealed design that uses servo tech to achieve deep extension. I am also going to build a 5 channel setup of identical speakers to match. (Raw Acoustics HT2s - MTM using XBL motors and ribbon tweeter)
What speaker style (ported or sealed) will blend best with such a sub? My room is about 13' wide by 12' deep with 9' ceilings. It is in a finished basement and hs openings to the left and right rear corners.
I am leaning towards sealed and get the sub rolled off at 12dB slope. Thus, the speakers would have an acoustic roll-off of 12dB to blend in together.
BUT,
The 80hz crossover applied in my receiver's bass management will add to this, won't it? With sealed speakers, will this result in a 24dB slope or will it remain at 12dB?
Ideally, I think 12dB will be easiest to blend, but I am not sure.
Help?
Old 28th December 2006, 06:18 AM   #2
I would suggest go with sealed for the HT2s and the servo sub. It's a lot to ask a small 4" woofer to reproduce mid-bass frequencies and lower at high SPL levels. So, IMHO you are better off runing them small.
You can use the crossover on the plate amp. Ask Brian for his opinion. Also, you might get more feedback posting in the subwoofer forum here and in the DIY forum in avsforum.
good luck,
Al
Old 28th December 2006, 08:02 AM   #3
I'm running my DS-12 in the recomended 2.1cu ft sealed box, my room is lightly smaller than yours (about a foot smaller in each dimension).
It goes plenty loud enough in my room and very deep, I'm having to use the highest extension setting on the amp and then attenuate the low end slightly with my BFD to control the low end. You get a lot of room gain in my room, running the filter at the 14Hz setting and no BFD gives about +15db @ 10Hz, which is fun
I think (not 100% on this) THX spec recievers/processors have an 80Hz 2nd order HPF on the main speakers, and 4th order LPF on the sub channel. So if you defeat the LPF in the sub and use main speakers with an 80Hz 2nd order rolloff (as THX suggests) you end up with a 4th order slope on the mains.
Old 30th December 2006, 11:31 PM   #4
Default Sounds Good
I played around with plugging the ports of my mains and adjusting the crosover to integrate and I am liking what I hear. Kettle drumms in particular sound much better and more distinct.
I think I will go with sealed Speakers and Sub.
Thanks,
AF
sealed vs. ported sonu Multi-Way 25 9th May 2005 12:50 PM
Sealed or ported? mazeroth Subwoofers 13 23rd November 2004 12:44 PM
¿Sealed or Ported? eXn Car Audio 28 11th October 2004 11:05 PM
opinions of T/L box V ported OR sealed busterno1 Multi-Way 13 28th November 2003 08:20 AM
Ported mains / Sealed sub Javaman Multi-Way 3 27th December 2001 09:56 PM
Copyright ©1999-2017 diyAudio
