I've searched this forum (and dickason): for a given driver - how to best model boxes to predict and optimise vented box transient response . . some learnings:
"more gradual rolloffs have better transient response than steeper rolloffs" (If I were doing sealed, I'd aim for Qt of about 0.7, but I have some big drivers suited for vented) "wisely chosen vented alignments can produce bass as refined as a moderate Qtc sealed alignment". ~ Unibox simulates step response/ tone burst ~ Win ISD simulates group delay very interactively. I believe that settling time (rise time + the time of any "ringing") step response is generally the better compromise of fairly fast rise time with a slight overshoot, that best predicts transient response. . . ie rather than Win ISD simulated group delay - use Unibox's step response if I am right, the next step along this line of optimisation is looking at step response graphs - at what point is settling time achieved, and how much time difference is signifcant . . The multiple wiggles of a vented box's step response make comparisons hard - who could comment on my suggestion of a good yardstick - the mimimum time by which (Unibox's) step response is no more than ~ 0.1(?) Thanks |
#2 |
playing with Win ISD, I see for better transient response, build the biggest box, tuned low . .
. . the ultimate "alignment" of which is probably the Onken . . |
#3 |
The alignment called SBB4 in Dickason is the best vented enclosure for transients, and all I use. Current project uses Scanspeak 25W (the lower Q version) in 6 cu ft, with the box tuned to ~18 Hz. Bass is very clean, no hangover or "one-note-ness".
Several advantages; Earlier mild rolloff helps compensate for room gain. Driver is loaded to <20Hz. Driver excursion is reduced as you approach resonance. And in my experience, tuning is not particularly critical. The principal disadvantage is the box size. I also used this once in a commercial design, the 18W tuned to 28?? Hz or so, also with good results. As a general bias, I believe that keeping the driver loaded for all program content is a good idea, so for smaller drivers I prefer sealed. |
#4 |
Of the normal vented alignments, yes the SBB4 with those attributes is very appealing. (And the Scanspeak *W's with the SD1 motors are great drivers).
If a driver is suited to the Onken alignment - very high Vas I think is most important - and you can live with a giant box, reports suggest the Onken is best vented enclosure for transients. the Onken seems to be the final step along the spectrum of larger box, tuned low, yielding slow roll off and better transients. I'm looking at the best way to use a 15" JBL pro driver (the 2035, with a big but not massive Vas of 192 litres). Onken_calc.xls suggests (depending on Rg) a 285 litre box, but I don't want it that big The priority is transient resonse rather than depth. planet10 said in a similar thread a while back "The classic vented box alignments are an artifact of a time when we didn't have personal computer programs - and not even any calculators. back then it was a long tedious process to calculate out even one alignment. So they picked a few spots on the curve and generated tables & graphs so that anyone could easily generate those boxes. A vented alignment is a continuum of possibilities. Now with a computer program you can explore all the possibilities." Has anyone simulated step response in Unibox, and found they could employ the results to fine tune their design, ie go beyond SBB4, knowing in building a bigger box that they gained something tangible ? Thanks |
#5 |
I certainly agree with the continuum comment. I don't use classic alignments as such, I mentioned SBB4 as a way to connect to the Cookbook. I use LEAP for modeling and do final tuning with the Sheffield drum record for minimizing overhang. Frequency response falloff is chosen to more or less match room gain.
#6 |
Curmudgeon
Does LEAP allow simulating of step response, or do you think that could be worthwhile? Cheers
#7 |
Yes it does, but I don't use it; I used the delay curves instead. Nowadays, I tend to use the freq response more, and the delay curves a bit less, as I choose the driver and box size to put me in the SBB4 (or Extended Bass Shelf) territory to begin with. I did spend a lot of time the first time through the loop (10 years ago?) to decide that that was the "alignment" I wanted to use.
Oh, and to emphasize the Sheffield drum record; the notes say the kick drum should be totally dead. With a significant alignment error, I've heard it Baarooommm. When it is truly dead, the transient response (which is actually more lack of hangover I think) is very good. I don't think the disk is still available, and I don't know a substitute unfortunately. |
#8 |
Hi rick57. greetings from the Sunshine State, I don't want to confuse things but you might reconsider going for a Qt of 0.7. I am aware that this number is frequnetly seen as the optimun and gives "Butterworth" or maximally flat response. On the other hand as the bass end there is a good case for a lower figure. My source is Martin Collom's book "High Performance Loudspeakers" (various editions since 1978. I think the 5th is the latest). He maintains that a figure of 0.6 gives a better subjective response. The maximally flat response tended to sound too bassy and loose. Its a v.good text and might repay checking out at a local library if you can get it. Enjoying the weather down there this week? I lived there during the 70's and can recall leaving a building in sunshine having a coffee in Lygon St Carlton and returning 75 minutes later. During that time it rained and snowed but the sun was shinning by the time I headed back. You've got to love it!
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#9 | |
Curm and any others, If you want the Sheffield Drum record, it's available on CD and for sale by Winston Ma of FIM. Go here: http://www.fimpression.com/detail.aspx?ID=85 HTHs, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#10 |
Well, that's an interesting site! Thank you.
| Controlling transient response | AdamZuf | Tubes / Valves | 29 | 6th July 2007 01:38 AM |
| Vented alignment to maximise transient response | rick57 | Multi-Way | 31 | 3rd December 2004 06:12 AM |
| Transient response on underdamped sub with EQ | mikee12345 | Multi-Way | 13 | 24th June 2004 11:41 PM |
| Transient Response Testing | cm961 | Multi-Way | 37 | 22nd March 2004 09:57 AM |
| EBS transient response | Solid Snake | Multi-Way | 1 | 1st February 2004 05:26 AM |
| Page generated in 0.11178 seconds (89.37% PHP - 10.63% MySQL) with 10 queries |
