Old 22nd December 2006, 04:14 PM   #1
Lindahl is offline Lindahl  United States
Default High-output 6 speaker 3-way D'appollito? (PSB Plat C4)
Anyone aware of a DIY design similar to the PSB Platinum C4 that's designed for high output with 2 woofers, 2 midranges and a tweeter and decent off-axis response (35 degrees horizontal, 15 degrees vertical)? Looking for large stand-mounted high-output LCRs to go behind an acoustic screen. A small LCR line array similar to, or slightly larger than the RBH T1, MK S150, or Klipsch THX Ultra2s would be great, too.
Thanks!
Old 22nd December 2006, 04:31 PM   #2
Oops, I realized I said 6 speaker, I meant 5 . I should have gotten more sleep last night. A few more things...
I should probably mention that my budget is about $800 each, preferrably ~$600. Sealed with a target crossover to seperate subwoofers at 60hz or 80hz is ideal - I'm looking at IB right now. I'm not looking to go low, so the Ws of the WMTMW design would be maybe 6.5" or 7" and the Ms would be around 3" or 4", I'm guessing. Not really interested in a ribbon T since their vertical off-axis response falls off very sharply, from what I've seen (5 degrees or so).
I suppose the crossover between the M and T is key, but I'm looking to be on the warm side of neutral. I have pretty good extended hearing (at least 18khz) and I can't stand speakers that become harsh when they're pushing reference levels.
Thanks!
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 07:49 PM
Driver suggestions for high output open baffle speaker paulspencer Multi-Way 26 28th October 2006 04:47 PM
Is this due to high DC at output? Please help!!! safetyman Chip Amps 28 28th March 2006 11:29 AM
Building a high output speaker Solinar Multi-Way 7 13th May 2004 05:36 PM
Page generated in 0.06882 seconds (70.96% PHP - 29.04% MySQL) with 10 queries
