Old 21st December 2006, 12:23 AM   #1
Default router bits for flush mounting
what router bits are needed for flush mounting a speaker?
That is, for the recess and hole cutout?
Old 21st December 2006, 01:52 AM   #2
Tenson is offline Tenson  United Kingdom
A two flute straight cutter long enough to cut the thickness of the wood? you also need a circle jig. I made mine with a bit of wood and a nail! Not the best solution though.
Old 21st December 2006, 02:15 AM   #3
rdr is offline rdr  United States
And a 3/4 for the recess. Get carbide. I about burned down my garage with a regular one. MDF is tough on bits.
Old 21st December 2006, 02:55 AM   #4
okay, so I want 3/4" carbide straight flute bits?
I have a jasper jig, but unfortunately it doesn't fit my black and decker plunge router. I guess I can just drill a new hole to attach it to the router.
Old 21st December 2006, 05:39 AM   #5
Send a message via MSN to noodle_snacks
if you have not already purchased the bits, i'd personally go for solid carbide spiral upcutting ones, the cut quality is better, and they remove the chips as they cut, leaving less heat around the bit and ultimately lasting longer.
Old 21st December 2006, 09:02 AM   #6
pinkmouse's Avatar
If your MDF is veneered, then I'd go for spiral downcut.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 25th December 2006, 05:47 PM   #7
http://www.rockler.com/product.cfm?page=5298
would something like this suffice?
Old 26th December 2006, 08:25 AM   #8
Yes, but if you are planning to get a fair bit of ouse out of them, then i'd go for a really high quality, brand-name bit like CMT or Frued.
Old 26th December 2006, 01:12 PM   #9
jackinnj's Avatar
i use a 45 degree bevel or a chamfer bit. if you're only making one set of speakers HSS is OK.
If you get the Jasper router jig, set your center and then make the first cut the outside diameter of the speaker (to the depth required -- usually anywhere from an 1/8th to 1/4 inch), then cut the inside diameter of the speaker all the way through (in several passes). a 45 degree bevel bit can then be used for the final cut if the fit is too tight.
Helps to wear a dust mask when you do this.
Old 26th December 2006, 02:02 PM   #10
Aengus is offline Aengus  Canada
Aengus's Avatar
You can also cut the speaker hole and then use a bearing-guided rabbeting bit to cut the flange recess. This is useful if you are retro-(flush)fitting in an existing cabinet.
jackinnj, I second the 45-degree bit suggestion, but disagree about HSS. If you have a router, you're going to continue using the bits, either for speakers or for something else. Buy carbide-tipped (or solid-carbide, though these are quite pricey) if you can afford it at all. If you buy the good tool, you only have to buy it once - a lesson I seem to need to relearn periodically.
Regards.
Aengus
Safely using large router bits? ShinOBIWAN Multi-Way 25 21st April 2008 08:10 PM
Heads UP. Super deal on router bits! rcavictim Equipment & Tools 7 26th September 2006 03:17 PM
Tweet/mid flush mounting Puggie Multi-Way 3 17th January 2005 06:11 PM
Help : Best way to flush mount speaker drivers and other router tips wanted?? Cacophonix Multi-Way 7 23rd April 2003 07:47 PM
substitute for flush mounting Chris_W Multi-Way 8 9th May 2002 02:25 AM
Page generated in 0.10016 seconds (80.05% PHP - 19.95% MySQL) with 11 queries
