Old 20th December 2006, 03:00 AM   #1
Default Loudspeaker Enclosure
I've made many of speaker boxes over the years with MDF. For my new project I'd like to make something that looks really nice.
I would like to make the design similar to the design of the swan S600HT, which is a rectangular box with some rounded ends.
http://www.swanspeaker.com/index.asp
Should I make it out of MDF and vaneer it or should I make it out of hardwood (mahogany is my preference)? I haven't done either so I wanted to hear some pros and cons
Old 20th December 2006, 03:20 AM   #2
wigginjs's Avatar
Interesting question actually. I was just thinking about how you would veneer speakers that had round-over edges. My guess is that you can't do it because it would require all sorts of strange cuts to the veneer in order to get it to lay flat on the corners.
The Four Chairs
DIY Home Theater
Old 20th December 2006, 04:52 AM   #3
its not hard to veneer roundovers.i just use paperback tenderized veneer.wraps around no problem.
Old 20th December 2006, 10:40 AM   #4
wigginjs's Avatar
I mean to veneer the coreners of a box that every edges has been rounded over.
The Four Chairs
DIY Home Theater
Old 20th December 2006, 01:22 PM   #5
Send a message via AIM to clearwaterms
i think he means where the corners are rounded over as well as the points, so it ends up looking like a wooden version of a fuzzy di
if (and Im not sure that it would) a hard wood would be a problem instead of MDF, why not make the speaker a little bit larger, just attach full 1/2" boards to all sides of the speaker, and then round that over. You still get the quality of MDF under it, and then you get the look and appearance of hardwood on the outside
Old 20th December 2006, 06:53 PM   #6
not a bad idea. I guess that would be the same as using a vaneer but thicker so I can route it.
Old 20th December 2006, 08:20 PM   #7
tinitus is online now tinitus  Europe
Or you can route into all corners, 90 gr. - and glue hardwood in all corners
Next you glue veneer all over - then you can route/sand the corners
But this applies only to moderate roundings
If you want bigger roundings, you can route/cut edges 45gr. - and glue hardwood with proper thickness onto the corners/edges
In this case you will have to strengthen the cornes on the inside of box
Veneering as above
good luck
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 83 16th May 2011 12:27 PM
Switching car audio enclosure to home enclosure wattz Subwoofers 10 18th April 2010 05:51 PM
RJ loudspeaker enclosure plovati Multi-Way 13 1st September 2005 01:51 AM
3-way 10/12" Loudspeaker Enclosure makaveli17 Multi-Way 0 7th April 2004 09:47 PM
Page generated in 0.08927 seconds (74.59% PHP - 25.41% MySQL) with 10 queries
