Old 20th December 2006, 02:45 AM   #1
Default Jig question
Do I need a wallin jig or is there something else that is simple out there? I'm a little intimdated by the complex schematic
I've purchased a Behringer ECM 8000, Behringer xenyx 802, M audio transit sound card. I plan to use ARTA to measure FR and speaker parameters.
Old 20th December 2006, 12:04 PM   #2
claudio is offline claudio  Italy
claudio's Avatar
Hi Jeff,
for acoustic measurements you can use a simpler jig: check my home page, you will find all the infos. Be aware to use lot of care, not to burn your Transit.
______________________________
My Home Page: www.claudionegro.com
Old 20th December 2006, 06:54 PM   #3
All I saw on your website is the wallin jig. I must be missing what you are refering to
Old 20th December 2006, 07:01 PM   #4
claudio's Avatar
For acoustic measurements: folder SW Acoustic. Meas. / Cables
For electric measurements: folder SW Setup / Cables
Old 20th December 2006, 08:23 PM   #5
what were you refering to when you said be careful not to burn my transit. Is there an order in which I should connect the wires or is it the line in must be set at a certain voltage level or something so I don't overload it.
Old 20th December 2006, 09:02 PM   #6
claudio's Avatar
You must take into consideration that usually the sound cards max input voltage is 2.5 V or less, therefore feeding your LINE IN with an higher voltage will cause damages to your card.
It's all written in my HP, please take some time to read it all.
Old 20th December 2006, 09:31 PM   #7
Couldn't he use a voltage divider similar to what is used for Soundeasy to protect his card?
Old 20th December 2006, 09:41 PM   #8
claudio's Avatar
Sure he can, I describe this option (voltage divider) as well, in my HP.
In acoustic measurement, using the jig I suggest, there is not the need of any voltage divider IF you pay attention to the mic-pre volume; when using the reference coming from the amplifier output, however, you need a voltage divider. I don't use, and therefore compensate, the amplifier output as reference, being its response flat in the audio spectrum.
Old 25th December 2006, 06:03 PM   #9
I built a jig that essentially the cables Claudio described, but in a box with a couple of switches to make it easy to go from calibration mode to measuring Z or frequency response. I found that my sound card has enough drive on the line out for doing impedance measurements.
Study Claudio's tutorial and start with a really basic jig - you can modify and add to it as you go.
Thanks Claudio for your tutorial - it really helped me get going with Speaker Workshop.
Old 25th December 2006, 08:09 PM   #10
claudio's Avatar
I'm glad it helped you out!
Many informations of my tutorial can be used for others measurement programs as well.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10741 seconds (76.39% PHP - 23.61% MySQL) with 10 queries
