So what is the preferred audiophile type of of banana plugs, soldered or solderless, nickel or gold plated., guage of wire 14, 12 or 10 ? is electrical cord just as good, speaker wires cost more than double for softer PVC jacket ?
How do you terminate your plugs, I am leaning for the Safe-Connect as the best ? heres a sample: http://www.speakerrepair.com/Merchan...e=black_chrome http://www.speakerrepair.com/Merchan...e=safe_connect http://www.speakerrepair.com/Merchan...ory_Code=spade |
#2 |
Custom Title
I'm of the opinion (Being a cableguy) that cable construction does indeed matter, and there are many discussions of this subject on the web. Less here, because it's generally frowned upon at diyaudio. My preferred speaker terminations are spades over bananas, but if you must use bananas, use BFA types, lots of contact area. The Audioquest connectors are my favorites, several retailers carry them.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
i use WBT topline for all my connections...they break your bank, but they are the best stuff you can get. 5 times plating, and rated up to 400amp continuous for the binding posts. i have not come across a product by WBT that doesnt impress me...
#4 |
Custom Title
My experience with the WBT stuff is that it's not particularly good sounding. Too many platings, too much complexity, and except for a few key items, low conductivity base metals. The eichmann cable pod is a good minimalist binding post, but my faves are the cardas patented type- gets you one HELL of a solid connection to a spade.
#5 | |
Personally, I just look for good solid construction,with maximal tight contact area for connectors. Usually this means I buy Neutrik. As for terminating speaker cable, I just use bare wire. If you get any corrosion problems, just chop off 10mm and strip back again. Much cheaper, and a better contact.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
Pinkmouse have you tried Neutrik SpeakOn products?
I like the professional sort of connectors myself, as they have usually have more contact area, better locking systems for better contact, self cleaning, better shielding and alot cheaper than exotic connectors. The only problem is when to bring in and test equipment that uses standard connectors ![]() Cables are a high debated topic, whether they make a difference and what to use depends on the rest of your system and ultimately what you can personally hear and want from your sound. Do a search for some of the past threads, there is a WEALTH of information. All I can recommend here is since you are posting on a DIY forum, start with the cheap alternatives first (ie power cables, CAT5) and experiment to get the sound you like, or whether or not it makes a difference at all in your system. |
#7 |
I think the same criteria that are applied to assessing loudspeaker drivers and other audio components should be applied to cables and connectors - MEASURE them. Otherwise it's all just guessing isn't it? Does anybody ever measure these things? Couldn't you just insert whatever cables/connectors you want to test into your setup, then measure what comes out of the loudspeakers and see what the graphs say? Anybody tried this?
PinkMouse - "Not one of us knows anything, not even whether we know or do not know, nor do we know whether not knowing and knowing exist, nor in general whether there is anything or not" Metrodorus of Chios OK - so how did HE know this?
Soft Dome |
#8 |
Hi Sd,
assuming that each termination generates an added 10 to 20mohm of resistance, what would we try to measure at the speaker that would reveal the effect of this 40 to 80mohm of resistance?
regards Andrew T. |
#9 | ||
#10 | |
If people say they hear a difference among different cables and terminations, those differences should be measurable.
Soft Dome |
| PPI plugs - the old flat speaker plugs | jol50 | Car Audio | 0 | 21st January 2009 09:28 PM |
| FE127E terminations? | Scribble | Full Range | 4 | 17th October 2008 09:20 AM |
| Pin Plugs - How ? | EdT | Multi-Way | 5 | 8th February 2007 04:16 PM |
| ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! | ssabripo | Everything Else | 3 | 26th October 2006 02:33 PM |
| cables for diy amps, preamps, and speaker cables ... | paulspencer | Solid State | 5 | 3rd August 2004 07:14 AM |
| Page generated in 0.11881 seconds (87.69% PHP - 12.31% MySQL) with 10 queries |
