New Hi-Res Toys
New Hi-Res Toys
Old 19th December 2006, 10:44 PM   #11
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
New Hi-Res Toys
The side must have a 4 degrees elevation angle so to make Jordan axis meet ear level at 2.5m.
Old 20th December 2006, 09:41 AM   #12
Salas's Avatar
New Hi-Res Toys
Default Aluminum Bliss
The kid's got a name: Aluminum Bliss
Looks this one is gonna take advantage of aluminum goods without the nasties. Will see.
Old 13th May 2009, 05:08 PM   #13
nicoch58 is offline nicoch58  Europe
Good new toys to play Salas
xcross at 150-300hz ??
Old 13th May 2009, 05:29 PM   #14
Salas's Avatar
New Hi-Res Toys
Probably, 500Hz the most if I wanna keep the high pass first order. Better a NL4 Speakon at the back so it may be done active or with external crossover to tweak.
Old 14th May 2009, 12:01 AM   #15
Inductor is offline Inductor  Portugal
Inductor's Avatar
Right. You can see the prototype holes for the previous binding posts.
Old 14th May 2009, 12:20 AM   #16
Inductor's Avatar
... and a 24 (mm) drill for the painel holes of the round mounting socket and pozy1 screw driver for the cable plug micro screws. Sorry taking so much space from you.
Old 14th May 2009, 01:04 AM   #17
Salas's Avatar
New Hi-Res Toys
Use Mogami W2921 quad OFC between NL4s. You will appreciate it.
Old 14th May 2009, 10:45 AM   #18
jzagaja is offline jzagaja  Poland
New Hi-Res Toys
Hi there Salas,
I will finish something similar with Bandor 150 instead. The transmission line in RAL9001, white gloss topcoat polished by the hand.
Old 14th May 2009, 12:06 PM   #19
Salas's Avatar
New Hi-Res Toys
Cool.
Old 14th May 2009, 12:54 PM   #20
New Hi-Res Toys
Polishing the topcoat is a hardest part of such a simple 1st order loudspeaker. Appended original Bandors proudly made in England :-)
New Hi-Res ToysHide this!Advertise here!
New toys but not sure what to do with them Abob89 Full Range 10 20th July 2011 11:59 PM
got some more class d toys Tekko Class D 5 28th November 2007 01:17 PM
Papa's new toys Holger Barske Pass Labs 14 15th January 2007 10:21 AM
My new toys pinkmouse Multi-Way 15 25th May 2003 09:31 PM
More new toys pinkmouse Parts 0 10th May 2003 08:20 PM
Copyright ©1999-2017 diyAudio
