Another unloved child from the Full-Range...
I just bought some full-range Audax 5.25" drivers and the tweeter already has a high pass cap. The vendor recommended that I leave things alone since the woofer would "naturally roll off" and would not need a low pass filter. Does this sound right? Would the woofer not waste energy and sound muddied "naturally rolling off" without a lowpass filter? Sounds simple enough for a little driver. Here are the specs http://www.madisound.com/pdf/audax/vp130g2.pdf Do you guys buy this natural rolloff concept? Would it sound better with a simple first order lowpass coil? |
#2 |
Speakerholic
Hi Carlos,
If Audax designed it that way, it probably sounds fine. Keep in the mind that the impedance of the woofer rises with the frequency so it might not be wasting the power as you suggest. How do you like them? |
#3 |
i let my 8" cheapos naturally roll off and it sounds fine.
such speakers only sound "muddied", as you call it, because they are rolling off and only playing the lower frequencies. just a cap would give a shallow drop off on the tweeter and lower freq and may well match the woofers natural roll off quite well. i'd recommend you give it a go and see what it sounds like for yourself. is it going to be all that hard to change it afterwards if you don't like the result? |
#4 |
Thanks. Because of other complications and for simplicity, I'm also evaluating using a nice Vifa single midwoofer with no crossover or anything. See my related "Kids Boombox" thread.
| 4th order lowpass with one transistor | AudioAngel | Solid State | 2 | 18th April 2007 05:42 PM |
| To Low Pass Or Not To Lowpass...That Is The Question | CarlosT | Full Range | 2 | 18th December 2006 11:45 AM |
| Lowpass filter design | diegot | Car Audio | 2 | 19th December 2005 05:00 PM |
| Lowpass or Bandpass???? | soundNERD | Chip Amps | 7 | 1st June 2004 06:16 PM |
| How to add a high / lowpass to an IGC / GC? | Cradle22 | Chip Amps | 27 | 8th December 2003 09:31 AM |
| Page generated in 0.06945 seconds (83.84% PHP - 16.16% MySQL) with 10 queries |
