horn-loading standard dome tweeters
Old 19th December 2006, 02:23 AM   #11
LineSource is offline LineSource  United States
LineSource's Avatar
Originally posted by jzagaja
Do you know how thick the 300 ppi PUR foam is used in Geddes Summa Cum Laude?
As the soundwave is reflected at the mouth, and then again at the throat, it will travel through the foam a minimum of THREE times. From the absorption table below, 0.5"**3 would provide almost complete absorption down to 400-500Hz. So, experimenting with 0.25" and 0.5" 30 pores-per-inch foam would seem to cover midrange-tweeter range.
30 ppi polyurethane foam...1.00 = 100% absorption
......frequency...........125.....250......500.... ..1000......2000......4000
Foam:.polyur.. 1"_____0.13___0.22___0.68____ 1.0___0.92___ 0.97
Foam:.polyur.. 1/2"___0.09___0.11___0.22____0.60___0.88____0.94
I do not have enough experience with waveguides to give advice on using a JORDAN JXR6 HD. I would probably look at a 2" compression driver first.
It seems that there are few front loaded Jordan horns.
http://www.maclementhorn.it/TqwtHorn.htm
Old 19th December 2006, 06:42 AM   #12
Cameron Glendin is offline Cameron Glendin  Australia
Why not just buy one, Peerless have a horn loaded version of their classic tweeter. 99 db @ 1 meter/ 1 watt.
Old 19th December 2006, 07:51 AM   #13
tubee is offline tubee  Netherlands
tubee's Avatar
Here's a (german) firm who makes horns from artificial stone:
http://www.phio-audio.de/
Daisy Bell
horn-loading standard dome tweetersHide this!Advertise here!
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
Coax tweeters: unwanted horn loading? Klimon Full Range 2 7th September 2006 10:18 PM
Effects of non standard boundary loading a port exit? ShinOBIWAN Subwoofers 4 30th July 2006 06:31 PM
FS: Dome tweeters johnmik Swap Meet 0 18th June 2006 03:57 AM
