Building my own speakers
Old 17th December 2006, 12:00 AM   #1
Supa is offline Supa  United States
Default Building my own speakers
Hey guys,
I'm fairly new to building my own speakers, so i was just after a little help regarding the cabinet dimensions for the type of speakers i have.
I purchased 2 Vifa P17WJ-00-08 woofers
http://www.speakerbits.com/net/catal...aspx?ID=VF170B
And 2 Vifa D27TG-45-06 tweeters
http://www.speakerbits.com/net/catal...aspx?ID=VF027C
I also have 50mm ports.
Obviously im making 2-ways, but after a little research, I found my original dimensions for the box of 440x205x295mm may not me correct.
Can anyone help me regarding the correct dimensions for these specific speakers?
Cheers.
Old 17th December 2006, 01:01 AM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
That's about a 26.6 litre enclosure tuned to 43Hz, flat fr to about 55Hz according to my calcs and WinISD. Looks fine, although the port dia. might be a bit small for that box.
You could download WinISD and play around with the tuning/box dims etc. The P17WJ is in the driver database.
Jeff
Old 17th December 2006, 10:32 AM   #3
Thanks for the reply Jeff.
According to WinISD, it says I need a volume of 21.7 liters and a tuning frequency of 42.79Hz. It then gives me dimensions of 485x314x202mm (Height, Width, Depth), but that equals a volume of 30.7 liters.
How is that so? Am i missing anything?
If I stuck with the original box dimensions, would there be any change in sound compared to those given by WinISD?
Cheers
Old 17th December 2006, 11:23 AM   #4
Tenson is offline Tenson  United Kingdom
I always just use WinISD to tell me the volume I need then calculate the size from that myself. Seems to work, but remember the volume of the port is additional to the enclosure volume you tap in to WinISD.
Old 17th December 2006, 09:46 PM   #5
I would like to start today, so would my original dimensions suffice?
Old 17th December 2006, 10:13 PM   #6
CarlosT is offline CarlosT  United States
Interesting...a super low SBB4 alignment gives a box 19 liters in volume with a 19 cm length port (50mm diameter). Optimum Golden Ratio box would be 43 cm x 27 cm x 17 cm.
Old 17th December 2006, 10:16 PM   #7
Those numbers checked out on both AJDesigner and diysubwoofer.org spreadsheets...both free programs.
http://www.diysubwoofers.org/prt/ported.zip
http://www.ajdesigner.com/downloads/ajvented.exe
Building my own speakersHide this!Advertise here!
Building sensitive speakers sifis_samos Multi-Way 13 24th June 2009 02:52 PM
Building my first set of speakers. Feebz Multi-Way 14 6th February 2006 06:28 PM
help on building floorstanding speakers sr2002 Multi-Way 5 25th August 2005 07:18 AM
Building a set of PA speakers, any help appreciated. 5th element Multi-Way 36 15th June 2004 12:47 PM
building some tower speakers, could use some help theturtle Multi-Way 1 18th November 2002 04:44 PM
Copyright ©1999-2017 diyAudio
