I have an old project I am starting on again. I bought parts on ebay from a company that has gone away(Zetag). I have the drivers and the parts for the crossovers, and specs and drawings for the cabnets. I am trying to find out what the crossover points are. Design is a tweeter, upper woofer and lower woofer. The 2 woofers are the same, they are aluminum/magnesium/copper cones. Tweeters are custom made by Vifa. The crossovers are 12db 2nd order, here is what I have:
tweeter, 8 ohms, .6 coil and a 4.7 cap, about 3000Hz ? upper woofer, 6.5 ohms, .7 and .1 coils in series, 3.3 cap = ????Hz lower woofer, 6.5 ohms, .7 and .7 coils in series, 2 3.5 caps parallel = ????Hz Anyway to determine accurate crossover points from this info? I do have all the speaker specs, if needed. Thanks for looking. Dan |
#2 |
Hi Dan,
The only way of pin pointing the crossover Fs would require the Z of the drivers at the design xo freq. It would be better to assemble the lot, and do a sweep, measuring the near field response from each driver, or the signal fed to each driver. Usually, designing a crossover starts with formulae / calculator, then trim values if required. So trying to reverse engineer just on component values is a bit "hit and miss" Geoff |
| Crossover points and music power distribution | Prune | Multi-Way | 66 | 5th April 2005 11:02 AM |
| Bss Fds340 Crossover Points ! | Javier Alvarez | Solid State | 0 | 2nd June 2004 02:59 PM |
| What are the common audible crossover points? | dih1118 | Multi-Way | 2 | 22nd September 2003 09:12 PM |
| Do crossover points really mess things up? | BAM | Multi-Way | 3 | 2nd June 2002 05:57 AM |
| crossover points | ogp | Multi-Way | 1 | 17th January 2002 10:20 PM |
| Page generated in 0.07785 seconds (69.08% PHP - 30.92% MySQL) with 10 queries |
