Old 14th December 2006, 09:17 PM   #1
Default Focal Driver recommendations
Who here has had experience with the focal drivers? Ive been looking into purchasing some to make a high end 2 way bookshelf and later a floorstanding 3 way.
Ive picked out these drivers to use:
Audiom TD5 Tweeter
6 W 4311 or Audiom 6 WM
and then for the 3 way using a
Audiom 11 WX
Old 15th December 2006, 03:11 AM   #2
CLS is offline CLS  Taiwan
For a 3-way, I recommend Audiom7k for midrange. I've been using it for more than 10years. Superb performance!
But it's also out of production for many years
The successor seems not as good on paper...
Old 15th December 2006, 04:40 AM   #3
I believe the drivers I listed are the same used in the utopia range???
Old 15th December 2006, 10:59 AM   #4
float is offline float  England
Hi Nick,
not the same as Utopia range, but quite similar, at least to the older Utopia. The latest range uses beryllium tweeters ( a big step up) and multiferrite mids.
Bear in mind the audiom 6wx is a mid only, and no use in a 2-way.
Use this in a 3-way with your other drivers and you have the potential for an incredibly dynamic and transparent system from top to bottom.
Make one panel in acrylic so you can gaze upon the beauty of the 11wx
I w isH i cuold typpe bettr
Sub driver recommendations smallangryboy Subwoofers 0 3rd August 2008 12:11 PM
6C33 driver recommendations arnoldc Tubes / Valves 3 15th January 2007 10:23 PM
Driver recommendations... moray james Car Audio 4 19th September 2006 06:19 AM
Driver recommendations The_Mox00 Multi-Way 5 5th September 2006 06:58 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.07433 seconds (68.19% PHP - 31.81% MySQL) with 10 queries
