ok,
here is my idea: use 4 4"-6" drivers and one tweeter per channel. each driver on each side of enclosure and tweeter on top panel. for a 4" driver, what frequency should i start rolling off HF so that they act like a omnipole at all frequencies at say 5 feet away? and the same ? for the 6" drivers. i want to run them fullrange and just put a cap in series with tweeter for x-over. so... will a 6" drivers on each side act like a omnipole at higher frequencies, or should i stick with the 4" drivers? i hope you understand my question. Thanks!
It is not you... you are it. |
#2 |
no answers yet?
#3 |
I think you need to look at a polar plot for the driver. 3db down at 45 deg off axis is where they will overlap. Above that F they will start to beam.
Rather than have a driver on the rear, I would place it on the top, or 2 on the front. I tried an array of 4 4" DCs on an arc many moons ago. Spread the upper mids OK, but couldn't get the transient attack I wanted. You may have to build a mule and try different combo's. Geoff. |
| Global Feedback Source Point | gingertube | Tubes / Valves | 3 | 1st August 2005 11:21 PM |
| Page generated in 0.06939 seconds (65.97% PHP - 34.03% MySQL) with 10 queries |
