Old 13th December 2006, 11:44 AM   #1
freddi is offline freddi  United States
freddi's Avatar
Default Coupled cavity aspect of Karlson enclosures
A few impedance curves and two examples of response modification by adding a fold-over stub to front chamber which connected via a ~2" gap between the port board and inside surface of "wings"
for a new builder there might be things to tonally juggle and perhaps ways of reducing ripple and "echo".
the little box with 80 liter rear chamber and low Q/ low mass (~103g) 18" although not extended in LF was reasonably punchy on drums at 3/16" to 1/4" peak to peak and 300 watt peaks
were Karlson a type of bandpass or a bit more? can one be built with good sensitivity that will play flat to 50Hz half-space or has this exceeded its practical limits vs bulk?
http://www.audioasylum.com/forums/HU...es/116427.html
"Karlsonology" (Karlson enclosures/technique) what's happenin' ? freddi Multi-Way 45 29th January 2008 09:06 PM
base cavity? anonymoose Multi-Way 6 11th June 2005 05:49 AM
coupled cavity sub maquiniana_phil Subwoofers 3 19th May 2005 06:27 PM
Page generated in 0.05812 seconds (65.24% PHP - 34.76% MySQL) with 11 queries
