Scrap enclosure because of uneven sides and back panel not flush?
Old 12th December 2006, 04:11 PM   #1
omarmipi is offline omarmipi  United States
Send a message via AIM to omarmipi Send a message via Yahoo to omarmipi
Default Scrap enclosure because of uneven sides and back panel not flush?
I am construting JohnK's (Zaph) Hi-Vi BS3 project. I have already assembled the front, sides, top, and bottom of the enclosure. I noticed that the sides on both of the enclosures were slightly higher then the bottom and top so I (stupidly) sanded down the sides with an orbital sander. Hence my problem... Because I didn't sand the sides down level the rear panel of my enclosure does not sit flush with the rest of the enclosure.
Is there anything that I can do to rescue this project? I trired leveling the sides with wood glue and mdf saw dust but that didn't work. I also filled the boxes with shorthair fiberglass so the inside is not level enough to add a brace to act as a guide for a flush bit.
Thanks in advance.
Old 12th December 2006, 04:22 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Can you show us a pic or two?
planet10 needs your help:
Let's help Ruth and Dave
Old 12th December 2006, 04:53 PM   #3
Sure can... when I get home I'll snap some pictures. At least I got the chance to practice asthetics (filling in voids, sanding, priming, sealing).
Old 12th December 2006, 07:09 PM   #4
s7horton is offline s7horton  United States
unless I totally misunderstand, couldn't you run the back edges through a table saw and take off just a hair to make it straight and square again?
You'll make the enclosure smaller, but only by a very small amount..
Old 12th December 2006, 08:58 PM   #5
I had thought of that... only problem is I do not own a table saw. I'm working with a circular saw and a cheapo home depot straight edge.
Old 12th December 2006, 09:17 PM   #6
mazurek is offline mazurek  United States
Put rubber or felt feet on the bottom. Then it doesn't matter whether the rear is flush with the bottom.
Old 13th December 2006, 04:00 AM   #7
I'll let the pictures explain:
Old 13th December 2006, 12:57 PM   #8
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
You need the right tools to do a good DIY job and I would suggest as good fence and a router is a must.
This is an example of a great fence and you don't have to muck about with timber and clamps as a fence which can get in the way when sawing.
http://www.carbatec.com.au/store/ind...h=60_8360_8370
There's a saw base which is not needed as you run the saw against the fence but gives you an idea how it works.
http://www.carbatec.com.au/store/ind...h=60_8360_8400
A router is a must for DIY loudspeakers.... period.
I'd suggest you saw off the back panel (using a fence as a straight guide), cut a new panel a bit oversize, glue on and then trim the overhang with a router and trimming bit.
Anything can be fixed with patience and time.
No longer DIY active
Old 13th December 2006, 01:18 PM   #9
audio-kraut is offline audio-kraut  Canada
Another option - which would decrease the box volume somewhat, could you not recut the backpanel to fit inside the box?
I also think you have to cut more slowly. I have better cuts freehand
With a straightedge and cutting slowly, make sure the base of the saw is riding along the straightedge the whole length of the base.
Old 13th December 2006, 02:12 PM   #10
Jim85IROC is offline Jim85IROC  United States
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
Any cutting tool when combined with a straight-edge and some clamps will work wonders for those who can't afford/justify a table saw.
When I make my rough cuts, I clamp a known-straight piece of MDF into position so that my circular saw can ride along it throughout the cut. The result is a very straight edge. I do have to admit though, that even with a cheap jig saw, you should be able to get close enough free-handed that once you screw the panels together, the MDF will fit tight or very close to it.
If you're interested in learning how to build a professional looking box with virtually no tools, let me know and I'll type it out. It's a lot of typing, so I don't want to do it for no reason.
Scrap enclosure because of uneven sides and back panel not flush?Hide this!Advertise here!
Uneven distance from back wall? Lewis Moon Multi-Way 0 5th October 2008 10:12 PM
Enclosure w/ curved sides, need your help MITMechE Multi-Way 14 1st April 2004 11:08 PM
How to make a durable back panel? tktran Multi-Way 4 24th February 2004 05:41 PM
Copyright ©1999-2017 diyAudio
