Hi all,
I am very newbie about DIY loudspeakers... In fact i have never made a DIY speaker box... But i have a pair of that bass driver; Westra KW 160-1374 Qts = 0,5 Vas = 25lt Fs=45Hz Z=4ohm SPL=85dB dia=165mm With a 25lt vented enclosure i can get 45Hz F3 (Winisd says). I also have two of 4ohm two way (6dB) passive crossover from an old speaker. I want to make a pair of two way speaker box by using that drivers... What can you advice to me? If i buy two good dome tweeter (4 or 8 ohm) and make 25lt enclouse for each. That makes a good pair of speaker box? Or can you advice a different way to me? Thanks in advance for your helps. Best regards, Özgür |
#2 |
Wont anybody help me?
Or did i ask a stupid thing? |
#3 |
OK, the stock crossovers are unlikely to work well. You really need to measure the drivers, or at least find a frequency response plot before you can decide on a tweeter, then you can look at crossovers.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
#5 |
Thanks guys. I mean that.. That bass can give up to 4000Hz. So what can i do next? How can i buy (or make) a xover for it? And what type of tweeter should i buy, then how can i design a good enclosure for it?
Thank you again. |
#6 |
Nobody will help me?
#7 |
DX, you need to measure your driver first before we can recommend anything. Then we need to know what tweeters you can actually get - there's no point in us telling you about a wonderful driver that you can't buy!
#8 |
Measure??
Should i measure it in free air and give 1W signals from 45Hz to 4000Hz then measure by a sound level meter? And draw a curve of response? Well its too much for me.. First of all i have no acustic room in my workshop or home. Second is i have no signal generator. Conclusion; i should buy a new brand one.. What's your advice to buy a new 50W bass/midbass? Thank you Pink. |
#9 |
We're not so bothered about the bottom end, as that is mostly box influenced, we want to look at crossover frequencies. Download the free demo of Arta, and use a cheap computer headset type mike. You don't need a special room, just don't put it in a corner or against a wall when measuring. That will be good enough to get going, and learning to measure speakers is a very handy skill.
Oh, and you still haven't told us what makes of drivers you can actually get hold of easily!
#10 |
Is it that easy to measure my driver? I'l do it tonite..
However i couldnt understand that sentence because of my poor English; "Oh, and you still haven't told us what makes of drivers you can actually get hold of easily" Can you explain it a simpler way? Thank you. |
| Make it worse to make it better??? | moray james | Planars & Exotics | 23 | 12th May 2008 11:08 AM |
| What to make? | Mayday | Tubes / Valves | 3 | 5th December 2006 03:20 AM |
| Make ac dc. | Jasmeleg | Parts | 12 | 12th September 2005 06:14 PM |
| How make make a microchip, from a program? | multiplexor | Everything Else | 1 | 20th February 2004 01:24 PM |
| Page generated in 0.10055 seconds (77.29% PHP - 22.71% MySQL) with 11 queries |
