Old 12th December 2006, 01:17 PM   #1
Ghianni is offline Ghianni  Greece
Default Woofers replacement.
Hi all,
I own a set of sound monitors, "klein and hummel O98", for about 15 years. The problem is that the woofers appeared with the foam surround rotten. I have to replace them, but the manufacturer informed me that they do not support these monitors any more due to the lack of spare parts. They have attempted to refoam some woofers with no success.
I asked them to inform me for the type and make of the woofers in order to find compatible ones but they didn't give me that information, instead they offered me a replacement method for some $$$$ that I cannot afford.
Does anybody of you know what type and make are these woofers or suggest any new type for the replacement?
Your help would be very appreciated.
Old 12th December 2006, 01:30 PM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Have you pulled the drivers out? Any markings or pics you can provide?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 12th December 2006, 02:43 PM   #3
qwad is offline qwad  Australia
Do a Google search for "speakerbits.au. com"they should be able to help you with suitable foam surround replacements inc. suitable adhesive at a fraction of the price of replacement drivers doing it is not difficult, only challenges your diy ability; just a little care is needed and a little thought, also do a search on the net for a diy surround replacement primer, there is one as l have seen it, tho unfortunately l cant give you a link, good luck cheers TC
we all have problems only some people have more than most....
long live the Magyar (Hungarians) in the world!
Old 12th December 2006, 03:57 PM   #4
Here are the pics. The system is triamp 50+50+100 Wrms, 97dBSPL@2m@full power, Woofer dia=210mm/ 4 Ohm.
Old 12th December 2006, 06:36 PM   #5
Sonusthree's Avatar
The label appears to be in the same format as those made by Peerless. Only the top OEM marking is changed
I wonder if peerless can suggest a replacement?
Martin.
Old 12th December 2006, 06:39 PM   #6
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
That woofer looks like an easy candidate for a refoam, which gives you a much better chance of restoring the sound than if you try different woofers.
Old 15th December 2006, 03:06 PM   #7
agreed should be easy nough to get replacement surrounds..... for these
cheers TC
Old 15th December 2006, 06:17 PM   #8
I sent an e-mail to them and they replied: Unfornutaly, we have not produced the speaker, so we are not able to help you.
Before I will go for the surround replacement I would like to try another company may be SEAS.... what's your suggestions
Old 15th December 2006, 06:28 PM   #9
infinia is offline infinia  United States
infinia's Avatar
That is a genuine Peerless Woofer. possibly an OEM 10" 4 ohm paper cone foam surround version (part no. 930426 from your image)
Sealed enclosure/ or passive drone alignment right.
If you can find a Peerless distributor they can get something to work for this from his old Peerless stock. Unfortunatly they have discontined most of those woofer types about 1 yr ago.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Replacement woofers for Martin Logan Monolith II's horchem1972 Planars & Exotics 11 4th October 2008 06:52 PM
replacement woofers for component set taylorman Car Audio 11 9th February 2006 10:49 PM
Replacement Woofers for SZABO 424-A1 Gcollier Multi-Way 0 4th August 2004 07:16 PM
Replacement Woofers for existing cabinets GanjaMax Multi-Way 7 4th January 2004 06:14 PM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Page generated in 0.09788 seconds (76.15% PHP - 23.85% MySQL) with 11 queries
