Midbass J horn
Midbass J horn
Old 12th December 2006, 11:28 AM   #1
tade is offline tade  United States
Send a message via AIM to tade
Default Midbass J horn
I want to build a mid bass J horn to cover the kick drum area from eighty to maybe 500 hz. i will cross over to midrange probably around 150-200hz. That way I can put my two subs in optimal places in the room for below that, and whatever can handle the midrange and treble above.
I want it to be full size for its bandwidth.
I want to fudge compression drivers out of a pair Hi Vi B4N four inch aluminum cone woofers:
http://www.partsexpress.com/pe/pshow...TOKEN=17170838
That cone almost looks like a compression driver itself. Efficiency is absent but i figure with horn loading it will improve. I also like the idea of a four inch driver producing bass if it can, it should be quick. How should I figure out what size to make the throat and the front and rear chambers.
Many thanks and advice is welcome.
Old 12th December 2006, 11:51 AM   #2
Magnetar is offline Magnetar  United States
Banned
After horn loading that little 4" inefficient driver and building a full size horn you'll be lucky to end up with the sound of a good 10" direct radiator. IMO way too much work for the end performance - plus it will be quite large
Old 12th December 2006, 12:40 PM   #3
you know, i bet you are right. I should save the effort and save up for some PA tens.
Old 12th December 2006, 02:30 PM   #4
dwk123 is offline dwk123
I like the basic idea, but Magnetar is right - the HiVi's are pretty much useless for this application. No efficiency, and no motor strength. I looked at using 4 of the B3N's in a Unity prototype, and even 4 of them horn loaded only get into the low 90's, and bandwidth was disappointing (according to sims, never built it).
Old 12th December 2006, 02:48 PM   #5
what is good about compression driver midbass horns? The super high efficiency?
Old 12th December 2006, 02:57 PM   #6
this is what sparked my interest:
http://www.audiofederation.com/blog-images/IMG_9227.jpg
http://audiofederation.com/blog-images/IMG_9234.jpg
Old 28th December 2006, 11:49 AM   #7
rick57 is offline rick57
Somewhere there is a site with a clever project by a Swedish guy called matheus (sp??), to accomodate that horns really only behave like ideal horns when the WL inside the horn is several times shorter than the horn length, and allow this where floorpsace is limited, by a 90 degree midbass J horn (using IIRC a 15" JBL driver) - with a good "how I did it section"
It sounded like a very good way to get sufficient length for good performance down to about 80 Hz, "using height rather than length".
Does anyone have the link?
thanks
Old 2nd January 2007, 06:29 AM   #8
ears4hire58 is offline ears4hire58  United States
Banned
Yes, the super high efficiency and the uniform dispersion, but not the fidelity. I installed some in large auditoria (but now avoid the use of fiber-glass MB horns due to ringing)
Old 2nd January 2007, 08:53 AM   #9
Steve Schell who posts at the High Efficiency Speaker Asylum is developing new compression drivers midbass horns.
http://db.audioasylum.com/cgi/m.mpl?...ad&r=&session=
and others here
Steveis I think are for domestic use rather than auditoria. I don't know if fiber-glass, more likely I think with wood.
Cheers
Old 2nd January 2007, 12:01 PM   #10
There's also this thread referring to two bass horn with 15" drivers:
Steve's bass J horn (no links, but Steve can email sketches); and
Mathias *U bass horn (link gone, but drawings there)
http://www.audioasylum.com/scripts/t.pl?f=hug&m=117170
Midbass J hornHide this!Advertise here!
Straight front-horn for midbass EspenE Multi-Way 1 31st January 2009 05:17 PM
Midbass Conical Horn - Keele vs Hornsresp which is the better FR? steve71 Multi-Way 28 27th October 2008 07:35 PM
cost and sound-effective midbass horn - what works well?l freddi Multi-Way 0 13th November 2007 09:51 PM
dB Room gain in a midbass horn rick57 Multi-Way 2 13th January 2005 12:34 PM
