Old 12th December 2006, 08:30 AM   #1
tntman is offline tntman  United States
Question Fostex as a midrange?
I'm contemplating a unique three way system. I've never seen it done and any comments or experiences would be most welcome.
I'm thinking the Fostex FE168E Sigma would make a wonderful midrange due to it's extended frequency response. The loading is the only problem I can see. I've read several threads on this site about double bass reflex cabinet design. (WCOIL, if you read this I would appreciate your input)
I think I can get away from rear horn loading by using the double bass reflex for the fostex and seperating the enclosure from the woofer box. MTWW configuration.
Any suggestions?
Old 12th December 2006, 08:55 AM   #2
Hmmm........
What is the point of double reflex loading for a midrange ?
/sreten.
Old 2nd March 2011, 07:59 AM   #3
I have a similar idea. I plan to use Fe168eZ as a mid/fullrange from ca 150hz with a supertweeter on top.
In the bottom end i will have one active subwoofer for each channel. It is possible to let them roll of at 150hz with good results. (a future project would maybe be an active 10" mid/sub bass who plays at higher frequensies)
My question is the loading. What is the best solution? Is it possible to make it without any kind of filter? What about a closed sphere in order to avoid ripple?
Hans Erik
Old 2nd March 2011, 11:27 AM   #4
frugal-phile(tm)
planet10's Avatar
As sreten says, no point doing anything but sealed or aperiodic (an aperiodic TL is a favorite of mine) when used as a mid... or open baffle.
Basszilla uses a 208 as a mid, Von Schwikart (sp?) uses an FX120.
Any decent FR makes a great midrange, althou on some of them you do more harm than good by adding a tweeter (FF85k, Alpair7, Alpair10.2)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd March 2011, 12:25 PM   #5
Ok, some more Q.:
1) Do you have any suggestion for volum and baffel width for a sealed cabinet?
2) Will it be smart to use the Suprabaffle on a sealed cabinet?
3) Is "aperiodic" an accoustic vent (a port with foam inside)?
4) Will an OB solution increase the risk for exceeding x-max?
5) Is it possible to reach down to 150hz with one of theese solutions?
Old 3rd March 2011, 08:24 PM   #6
frugal-phile(tm)
planet10's Avatar
1/ depends on driver, FE168eS in sealed Q=707 box (3.7 litre) has F3 of 139 Hz
2/ outside of the box would be best if it has low diffraction and has no bafflestep until you get to the XO frequency
3/ that is one way of doing it. I like aperiodic TLs for midrange use.
4/ Yes
5/ yes
dave
midrange and fostex 166 tenderland Full Range 3 10th August 2006 01:56 PM
Fostex FP203: How to tame the midrange? Keith_R Full Range 2 28th March 2006 04:32 PM
Best Midrange Fostex Driver- Which one? Samuel Jayaraj Full Range 8 19th October 2005 11:52 AM
Fostex FE167E as midrange driver dhieber Full Range 14 18th May 2005 05:33 AM
Page generated in 0.09153 seconds (74.91% PHP - 25.09% MySQL) with 10 queries
