Old 12th December 2006, 01:59 AM   #1
Default tweet to match 4ohm vifa pl's
I was just able to snag some vifa pl18wo09-04's for a good price, so i am considering using them in an inexpensive 2 way setup. This project is just in its formative stage, so im trying to get some suggestions for a good tweeter to match before starting anything.
1.Would i be correct in looking for a 4 ohm tweeter to match?(to be used on a reciever capable of 4 or 8 ohm operation)
2.Should i be looking for dome tweeter, perhaps something that can
be crossed over low?
3.Any budget(sub $25 per speaker, less if possible) tweeter suggestions?
Old 12th December 2006, 09:18 AM   #2
Default Re: tweet to match 4ohm vifa pl's
No. the higher the tweeter impedance used the better.
Yes. Possibly.
http://www.zaphaudio.com/tweetermishmash
/sreten.
Old 12th December 2006, 04:19 PM   #3
thank you for the reply and link sreten. So it is acceptable to use an 8 ohm tweeter with a 4 ohm woofer? I was under the impression, and perhaps it is an erroneous one, that the amplifier sees the eight ohm load on higher frequencies and the four ohm load on lower frequencies. Would that combination be acceptable for the amp? Sorry about the stupid questions here, im an audio neophyte kinda learning on the fly
Old 13th December 2006, 06:41 AM   #4
respectful bump ttt
Old 13th December 2006, 10:58 AM   #5
Yes.
This is true.
Yes.
Note that you need a properly designed crossover, /sreten.
Old 13th December 2006, 09:00 PM   #6
olo111 is offline olo111  Poland
you should cross vifa pl as low as possible
(the driver is very good in bass, and not so good in mids)
so i suggest seas H1212
olek
Old 25th December 2006, 11:46 AM   #7
dre73 is offline dre73  Netherlands
this seems nice
http://www.troelsgravesen.dk/PL18XT.htm
Dayton RS150S-8 & Vifa D27TG-05-06 a good match? 14G-Dutch^ Multi-Way 11 22nd January 2008 06:43 PM
Tweet, tweet! weinstro Multi-Way 8 19th October 2007 09:29 AM
To Match Impedance on DI Box, or Not to match? MisterAlex Instruments and Amps 1 21st November 2004 10:09 AM
inexpensive tweeter to match vifa TC18WG-15-08 SQ Kid Multi-Way 15 7th August 2004 05:21 AM
Help! Which Vifa's to match some Signets???? Amras Multi-Way 3 17th December 2003 07:49 PM
Page generated in 0.09393 seconds (76.71% PHP - 23.29% MySQL) with 10 queries
