Old 11th December 2006, 12:59 PM   #1
Default Mesured Qts difference
I mesured Thiele/Small params with voltage divider technique and I experienced some differences. Fs are close to Vifa's specs but not Qts.
Vifa
Fs:39Hz
Qts:0.35
Mesured
Fs:39.5Hz and 40.5Hz
Qts:0.40 and 0.44
What should I do, use an average of mesured Qts, average of all Qts(including Vifa's Qts) ? I guess I'm building 2 cabinet of the same size ?
Thanks,
REALFLEO
Old 11th December 2006, 01:23 PM   #2
Did it Himself
richie00boy's Avatar
I would use average of what you have measured, ignoring Vifa specs. As that's what you will be actually working with.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 11th December 2006, 02:24 PM   #3
infinia is offline infinia  United States
infinia's Avatar
Hi
Now you must measure Vas.
Fs is right on.
Q is higher by some margin, run test again with smaller Rtest and current. <0R5 ohm
As you prob aready know the drivers should be "broken in" before results can be trusted.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 11th December 2006, 03:26 PM   #4
I didn't use too much current. All mesures were between 0.2-0.3V and I used a 1000 Ohms resistance.
I don't understand why you asked me to use a smaller resistance, I tought it was the point of the potential divider technique to use a "infinite" resistance ?
Thanks,
REALFLEO
Old 11th December 2006, 03:31 PM   #5
About Vas, I wanted to use Vifa's one because I read that a 25% error in Vas produce a small difference in QB3 vented alignment.
and yeah I broke in my drivers.
Thanks,
REALFLEO
Old 11th December 2006, 03:46 PM   #6
infinia's Avatar
Hi
I wanted you to use a completly different setup closer to the final application. If the results are the same, thereby verifing your initial test. You need a PA, sig gen, and a precision current measurement you will use I instead of V.
So I take it you don't want to measure Vas then. Often Vas varies with the Q for each driver resulting in a similar alignment for a constant box size.
Old 11th December 2006, 04:51 PM   #7
It's not that I don't want to mesure Vas, but I won't do it for nothing ...
I understand your point of counter verifying it with current. I'll do it to be sure.
Thank,
REALFLEO
Old 11th December 2006, 04:52 PM   #8
sorry
what do you think about this technique:
http://sound.westhost.com/tsp.htm
Old 11th December 2006, 05:10 PM   #9
infinia's Avatar
Regarding the link above.
Yes that is a good reference, he uses 10 ohms to measure the current. Might be more accurate for most AC meters. Use as much precision as you can before you do the math ..i.e. 1% resistor and 2% VAC.
Old 11th December 2006, 08:31 PM   #10
Svante is offline Svante  Sweden
Svante's Avatar
Could you provide us with details on how you measured Qts?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
strange mesured dips crazyhub Multi-Way 5 31st March 2009 08:07 PM
What's the difference? squirtacious Tubes / Valves 4 23rd October 2007 04:38 AM
How much difference 0.22 vs 0.33 cap? pengboon Tubes / Valves 1 1st July 2007 10:07 AM
I2C/I2S,what's the difference??? Leolabs Parts 2 18th April 2005 01:20 PM
What's the difference? 2.83V/1m - 1W/1m 1Time Everything Else 5 10th February 2003 03:54 AM
Page generated in 0.09503 seconds (78.16% PHP - 21.84% MySQL) with 10 queries
