Speaker Suggestions! - Page 3 - diyAudio
Old 19th October 2001, 03:09 PM   #21
Audiomobile (MASS series) are very good, but extremely expensive drivers. Several other suppliers (Blueprint, Lambda, Stryke, TC-Sounds) use the same 'Venezuela' cast frame, but without the chrome plating or other bells and whisles that inflate the price, but offer no performance advantage.
The best band for the buck these days are either the Shiva/Tempest from Adire, or the DVC 12"/15" from PE. These drivers use a Carbon Fiber layer epoxied to paper cone. As a result they are much stiffer than any poly cone driver, so far fewer cone breakup associated issues
[Edited by ThomasW on 10-19-2001 at 05:36 PM]
Old 21st October 2001, 08:39 PM   #22
Guys, Where can I find the design info( box, crossover) of drivers that you all have suggested. This info would help me to start my project right away.
I'll like to thank each and everyone of you who had taken enough time to provide me with an answer.
- XL.
Old 22nd October 2001, 01:09 AM   #23
Super is offline Super  United States
Send a message via AIM to Super
For general ideas, you should download some subwoofer enclosure design software. A basic, easy to use program would be WinISD.
http://www.speakerbuilder.net has the plans for a Dayton DVC sub. If you check out http://www.adireaudio.com they have a DIY section, and they also suggest designs to use with their drivers.
Also, if you go with the Shiva, try this link:
http://terryctheater.tripod.com/shiv...um/page12.html
I found it very helpful
Bryan
Old 22nd October 2001, 05:59 AM   #24
Xavier
If you go with Adire woofers then download the LspCAD demo available from the Adire site. It comes preloaded with the parameters of their drivers
If you use other drivers and have a version of Excel try using Unibox it's probably the most accurate of the freeware programs. WinISD has some inherent modeling issues especially with accuracy around 30Hz
suggestions - my first DIY speaker stephen123 Multi-Way 2 18th January 2009 06:43 PM
Speaker Suggestions for a Grado Fan. Lewis Moon Multi-Way 8 30th September 2008 04:55 PM
Suggestions for first speaker project tdstr Multi-Way 6 17th April 2007 10:14 PM
Speaker Suggestions for GC dsavitsk Chip Amps 7 25th February 2005 05:36 PM
HTPC speaker Suggestions... AZ_Ron Multi-Way 4 12th October 2004 07:39 AM
Copyright ©1999-2017 diyAudio
