Old 9th December 2006, 03:55 AM   #1
Default Any drawbacks to using ferrofluid in a low-excursion woofer?
Or retrofitting a pro woofer (of course the excursion would be kept in check)...
Power compression should be reduced, at least.
Old 9th December 2006, 05:07 AM   #2
infinia is offline infinia  United States
infinia's Avatar
Hi
Unless it's used in a low power midrange the fluid would get blown out of the gap reducing the heat flow benefits of the oil itself. Unless you could ensure this from happing ... I'm really not sure what you are asking/ getting at. Seems most VC power is dissipated by the air flow across the coil and former itself, so wouldn't it be a net loss if using oil for this application as it would block air movement. But like anything else it depends upon all the other factors/details as well?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 9th December 2006, 07:28 AM   #3
Unless there is inherent forced-air cooling (such as the dust cap forcing air through notches/vents in the pole piece of JBL's VGC woofers), ferrofluid should conduct heat away from the voice coil much more efficiently, since the thermal conductivity of air is less than almost anything except other gases.
Old 9th December 2006, 12:23 PM   #4
infinia's Avatar
A wise man once said "Identify and characterize a problem before you attempt to solve it".
I think this is more complicated than I know how to handle with out empirical data. As you pointed out movement might be a problem here. Possibly adding shearing forces to the oil and it's solid content perhaps reducing it's effectiveness. It's benefits to tweeter design is well known allowing the VC and former to be lighter at higher power levels.
Thermal compression is the problem then devise a test to see how bad it is and if the oil can be a solution indeed.
Old 9th December 2006, 12:48 PM   #5
My observation is that if something works people do it.
Ferrofluid damped woofers don't exist, tells me it doesn't work.
/sreten.
Old 9th December 2006, 01:14 PM   #6
infinia's Avatar
/sreten.
Good thing the innovators don't think like this, else we all would be living like the Amish.
Maybe not a bad thing (Amish) on the other hand.
Old 9th December 2006, 01:37 PM   #7
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
I know at least one pro audio manufacturer who uses ferrofluid in their woofers namely Community.
Se for example this Pro sub:
http://www.community.chester.pa.us/f...34e616cc06391f
Would be interesting to see their solution in more detail.
/ Anders
Old 9th December 2006, 03:40 PM   #8
You misunderstand, there were plenty of attempts to make FF woofers, /sreten.
Choke input PSU, drawbacks? dsavitsk Tubes / Valves 12 4th May 2007 11:52 PM
Drawbacks of Parafeed? dsavitsk Tubes / Valves 17 19th October 2006 09:08 PM
Line Array Drawbacks? MrPin Multi-Way 2 5th February 2006 08:51 PM
Where to buy ferrofluid ? thylantyr Multi-Way 9 10th May 2005 07:42 AM
High Excursion 8 Inch Woofer. Is Their Such A Beast? OMNIFEX Multi-Way 26 21st December 2003 03:22 AM
Page generated in 0.10993 seconds (76.99% PHP - 23.01% MySQL) with 10 queries
