Old 8th December 2006, 06:15 PM   #1
john k...'s Avatar
Default U-frame woofer design
(JPK) I read some comments in another thread about resonances in U-frame woofers so I have presented a series of measurements outlining how the U-frame is actually designed and just what you get out of it. The 1/4 and higher resonances which occur in a U-frame are also present in H frames and W frames, etc. The resonant frequencies are dependent on the length of the U or H, W.... so they may occur at different frequencies. In shorter H and W frames they may be higher in frequency and may be ignored altogether in some designs, relying on the crossover filter to attenuation their level. The resonances can be pushed higher in U's as well, but the damping is an integral part of the design and is still necessary. The length of all these "frame" woofers is always a trade off between where the resonances are, physical size and SPL capability.
http://www.musicanddesign.com/NaO-II-U-frame.html
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame Jim Shearer Full Range 595 9th January 2012 05:35 PM
PE Buyout 6" shielded AL cast frame woofer AdamThorne Multi-Way 1 19th April 2008 12:28 AM
Omega frame woofer Jaco Pastorius Subwoofers 5 4th March 2008 08:55 AM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 05:44 PM
Dipole Woofer Array in Multiple W Frame? MartinQ Multi-Way 9 3rd August 2004 10:20 PM
Page generated in 0.07023 seconds (71.17% PHP - 28.83% MySQL) with 10 queries
