thanks Francois
these DIY kits. - Technovox In Norrtälje
http://www.recone.com/crsweden.htm
They also sell a Video -
"Foundation of Understanding"
video on Loudspeaker Reconing.
This is the most comprehensive education on Loudspeaker rebuilding
you will likely ever find
It costs $40 - that money will almost buy a new Woofer!
Here is the main points in the video,
which shows how to do it:
Better than to use bicycle rubber tube
is of course if you could find sheets of rubber
in the size of A4 - then you can cut out a piece
in the form of a circle, that will fit the woofer better.
A very important thing here seems to "centre" the cone properly
so that it works properly.
/halo - the master of recone
I treied the link - It even is a swedish company sellingFrançois said:You can recone it. There is some company that does that: www.recone.com
They have a DIY kit.
http://www.recone.com/fou1.htm- A: Step by step reconing instruction
1: Identify the Loudspeaker for ordering parts
2: Proper cleaning of the speaker frame
3: Proper placement of new parts - Cone, Coil, Spider...
4: Centering the voice coil depth for maximum performance.
5: Assembling the parts dry.
6: Adhesive applications.
7: Testing and evaluating performance after reconing.
- B: Step by step refoaming instruction.
1: Identify the Loudspeaker needing refoamed or re-edged.
2: Proper cleaning of the speaker frame and cone for new foam.
3: Centering the voice coil for success.
4: Assembling the parts.
5: Adhesive application.
5: Testing and evaluating performance of the refoamed speaker
ok but i think i'll go for new woofers =) i found 3 candidates heheh tell me which ones are the best.. i like loud basss hehehe my amplifier is 2x100 and old woofers were 30w 8ohm..
Ones i want to bouy are:
MGR F-1808W --> 160W, 6ohm, 40-4khz.
Gamma BBK 200 --> 70W, 8ohm, 30-6khz.
Pro Audio SW830 --> 250W, 8ohm, 48-5khz.
Which should i go for?
Woofer replacement
I want to replace the woofers in my old speakers, i found 3 candidates heheh tell me which ones are the best.. i like loud basss... my amplifier is 2x100 and old woofers were 30w 8ohm..
Ones i want to buy are:
MGR F-1808W --> 160W, 6ohm, 40-4khz. (http://www.ljudia.se/cgi-bin/se/online/ljudia-online.cgi?id=703128 &cart_id=)
or Gamma BBK 200 --> 70W, 8ohm, 30-6khz. (http://www.hifikit.se/show_prod.asp?id=145)
or Pro Audio SW830 --> 250W, 8ohm, 48-5khz. (http://www.hifikit.se/show_prod.asp?id=285)
All are 8"
All are 8"
Throwing good money after bad.
The question is - was the woofer a very good quality one in the first place? If it wasn't it still won't be any better than new when it is fixed probably. If that is the case, buy a new one. You will be much more satisfied.
Halojoy, is your house the place where old woofers go to die? I can just imagine your back yard
- n00bie problem
