Hey,
what are You think about it? BTW 88zł it's something about 25$ In real it looks much better STX is of course polish manufacture |
#2 |
#3 |
#4 |
Looks a very interesting driver, woven kevlar cone, alu rear vented basket, shorting rings in the motor, overhung construction with 4.5 mm xmax. ALU voice coil former. Le is quite low (so the shorting rings are doing their work). However, not as extented as I hoped for, and an early cone mode around 1.6 kHz. More suited to be used in a low crossing design not for mid duties above 2 kHz, also the alu former will help in bass control and power handling.
For one second I thought that this are the drivers in the new Burmester B100, but the basket is different and according to Burmester they are sourced from a German manufacturer. Concluding: interesting driver at an even more interesting price point. My choice above cheap Chinese knock offs. |
#5 |
4.5mm Xmax = no thanks
#6 |
links to my mesurments:
http://img291.imageshack.us/img291/6...bwaterfcx4.gif - waterfall http://img158.imageshack.us/img158/8...xatbthdzw0.gif http://img123.imageshack.us/img123/1...08axatblq9.gif http://img123.imageshack.us/img123/9...51008axuc9.gif http://img158.imageshack.us/img158/7...fazastxlq4.gif DonoMan - why ? |
#7 |
Can you elaborate on the SPL level of the distortion tests? Your measurements backup my first impressions, still a very interesting driver.
But as always first use them myself before I have a proper opinion on sound quality. Do you have already some impressions (maybe from polish diy forum) on their sound? |
#8 |
polish pride! woo!
| Voice coil diaphragm speaker | Ed Holland | Planars & Exotics | 19 | 10th February 2009 06:58 PM |
| New 15" Field Coil Speaker | deadlyvj | Full Range | 2 | 6th June 2008 03:40 AM |
| oil in speaker coil section | space2000 | Multi-Way | 1 | 25th April 2008 11:29 PM |
| DC drive of twin coil speaker | psychosteve | Solid State | 9 | 6th May 2006 09:05 PM |
| Blown speaker (coil?) anything I can do? | aletheian | Multi-Way | 7 | 4th December 2005 10:54 PM |
| Page generated in 0.09886 seconds (73.11% PHP - 26.89% MySQL) with 10 queries |
