Old 2nd December 2006, 06:09 PM   #1
Default Impedance and current-source amplification
I realize that a current-source amp doesn't care about the impedance in that the magnitude of the current delivered is indepedent of the impedance; however, what about the phase? The current across an inductor lags behind the voltage, so from a conventional voltage-source amp the motion of the speaker would lag behind the voltage waveform going across its voice coil (I think).
Is it the same way with a current-source amp?
Old 2nd December 2006, 11:16 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Default Re: Impedance and current-source amplification
If you drive a loudspeaker with an ideal current source, the voice coil inductance and resistance does not affect the acoustic output at all. I think that answers your question?
With the normal near-ideal voltage source the output is greatly affected by both. The voice coil inductance acts as a lowpass filter, typically of order 0.7 or so*, and the resistance keeps the response from peaking at fs (the resonant frequency of the driver).
The resistance effect is highly desirable, but the inductance might not be.
*Yes, filters are not only of integer orders. Since the voice coil inductance has an impedance that typically is proportional to f^(0.7) one could say that the filter order becomes 0.7.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 3rd December 2006, 01:10 AM   #3
Default Re: Re: Impedance and current-source amplification
Seriously? The voice coil then looks like it has no inductance at all?
Old 3rd December 2006, 09:35 AM   #4
Svante's Avatar
Default Re: Re: Re: Impedance and current-source amplification
Yes. No. The inductance is still the same, but if the inductance varies, the output voltage of the current source will vary to compensate for that. Imagine that an ideal current source has an infinite output impedance. You can connect any impedance in series with that, and the output impedance will still be infinite, ie no change.
This has another positive effect; if the inductance is non-linear and causes distortion in the constant-voltage drive condition, it causes NO distortion in the constant-current drive condition. Funnily, the current source will produce a distorted voltage and this distortion compensates for the distortion caused by the non-linear inductance.
Old 3rd December 2006, 04:47 PM   #5
Okay, that might be true for an ideal current source amp.
Not that I am any expert on this, (far from it), but I am given to understand that in real life current source amps the output will vary quite a bit with the impedance variation. This is in direct contrast with most solid state amps with near ideal voltage source behavior.
Is this true?
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 3rd December 2006, 08:08 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Is this true?
Since Vout = Iout * Rload, with current amps, Iout is fixed for a specific level, Rload changes therefore Vout varies all over the place. But the idea is that Vout doesn't matter with current drive, it's the current that matters. And that is a fixed ratio to input signal.
So, yes, it's true, but who cares?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 3rd December 2006, 08:16 PM   #7
Svante's Avatar
Is this true?
No.
You can make a very-near ideal current source. It will of course have the same limitations regarding maximum output voltage and current as the typical near-ideal voltage source (=most normal amplifiers).
Here is a proof-of-concept design:
Old 5th December 2006, 04:37 AM   #8
I think you are right, but I am not sure. I wouldn't mind some verification on that myself.
I do remember reading in Audio magazine an interview with a prominent designer, (I forget his name). He said that he thought in a few years, the cone loudspeaker would disappear from the high end of the audio market because in one octave, the signal comes at you as if it is ten feet in front of you, but in another octave the signal comes at you as if it was much farther back. I think that might be what he was referring to, but once again I am not entirely certain.
-Anonymous
Old 5th December 2006, 04:47 AM   #9
Jan and Svante:
I think I botched up the wording of the post you both replied to.
When I said:
I was thinking of the SPL from a traditional moving coil speaker or speaker system , not the output the amp delivers to the speaker. If a speaker has an irregular impedance curve but a smooth SPL output when hooked up to a solid state voltage driven amp, I am given to understand that when the same speaker is hooked up to a current driven amp the SPL will vary with the impedance plot.
Am I correct on this?
-Anonymous
Old 5th December 2006, 06:14 AM   #10
Svante's Avatar
Jan and Svante:
Ah, I see! Yes, that is the big problem with current drive; it will peak at the system resonance(s). Effectively, what happens is that Qts of the driver becomes Qms and Qes is made completely unimportant.
The output towards higher frequencies will increase too, due to the voice coil inductance.
I/V after amplification using current amp? khundude Pass Labs 33 15th June 2008 10:44 PM
MC stepup and current amplification squadra Analogue Source 1 31st August 2005 06:53 AM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Can amplification based ta3020 amplify direct current signal? green3002 Class D 0 14th October 2004 06:01 AM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
Page generated in 0.13158 seconds (88.18% PHP - 11.82% MySQL) with 11 queries
