Old 1st December 2006, 02:44 PM   #1
Default Considerations for building a TWW 2-Way System
Hi there,
I've been looking all over for information/documentation on building a 2-Way speaker with 2 woofers. (TWW Configuration)
How will the xover network be affected (other than the load of course), what will become of the Re and all other drive parameters when hooked in series/parrallel... What about the dB/W...
I've found a lot of designs incorporating 2 woofers in either a D'appolito config or TWW but haven't found any pertinent documentation on the subject.
Anyone know of a site/resource where i might find such information ?
Thanks a lot
Old 1st December 2006, 03:02 PM   #2
try looking for information on 2.5 way speakers.
/sreten.
Old 4th December 2006, 11:53 PM   #3
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Here is one:
http://www.partsexpress.com/projects...e/ubt/ubt.html
Here is another:
http://www.zaphaudio.com/Waveguidetmm.html
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 5th December 2006, 12:37 PM   #4
You could use a design similar to mine (2 1/2 way) and use only one enclosure instead of two. (one sealed for mid, and one ported for woofer) It'd be cheaper as well since you wouldn' t need the crossover on the bottom woofer.
http://www.htguide.com/forum/showthread.php4?t=23211
Old 5th December 2006, 01:40 PM   #5
Hi, what your saying doesn't make any sense, /sreten.
Old 7th December 2006, 12:09 PM   #6
If you viewed the thread, you would notice there is an upper enclosure for the midbass and tweeter and a separate chamber, ported, for the woofer. WIth a two-way, I would put everything in the same chamber, ported.
My crossover is made of three components. One for the tweeter, one for the mid and one for the .5 woofer. If you made a two way, you wouldn't need the .5 portion of the crossover.
Make sense?
Old 7th December 2006, 01:27 PM   #7
Make sense?
More sense. You don't need separate chambers for a 2.5 way. Its
a design choice. You can also have separate chambers for a 2-way.
/sreten.
Old 7th December 2006, 04:51 PM   #8
Raoul is offline Raoul  United States
Hi s7horton,
Zaph actually did some tests that imply seperate enclosures for a 2.5 way may not be necessary:
http://zaphaudio.com/commonenclosuretest.html
Not saying that building two enclosures is a bad thing, but The results are pretty interesting.
Old 8th December 2006, 12:17 PM   #9
I don't disagree. It's not required. But I like the sound I get with a larger, ported chamber for the bottom end. It's tuned for that driver.
Old 8th December 2006, 04:04 PM   #10
Send a message via ICQ to TurboFC3S Send a message via AIM to TurboFC3S
My recent build is a 2.5 way with GR M-165x drivers ... one cab I did both woofers in a 1.65 cu/ft vented - the other was one driver in a .6 sealed, the other in a 1 cu/ft vented.
The 1.6 cu/ft vented version produced significantly more bass. I did quick measurements with my ECM8000 and Speaker Workshop ... but bass measurements are somewhat inconclusive. I trusted my ears more than the measurement, and they told me the version with both drivers in a shared larger enclosure was the way to go.
That's just one example though, based on my space and cabinet size limitations.
building EMG BQS system <>? woodbuilder Instruments and Amps 0 16th May 2008 02:58 PM
Considerations in enclosure-building for full range drivers Taterworks Full Range 2 23rd April 2008 06:00 PM
Building a system systemerror909 Multi-Way 6 29th April 2005 09:12 AM
Need help in building a system deathmetal Car Audio 3 9th October 2003 01:56 AM
Page generated in 0.13296 seconds (81.38% PHP - 18.62% MySQL) with 10 queries
