I have about a 3in,. tear in a 15" speaker cone and need to know what i can use to patch it. Any help would be great, Thanx.
#2 |
Do a search. I use PVA wood glue (no tissue) for such repairs. Only use tissue if you have a hole, the edges do not mate up. |
#3 |
I've used a watered down solution of weldbond(white glue) and a small piece of papertowel(bounty, the quicker picker-upper
) with good results. Put the patch on from the back(pre-soak it first) and apply a couple coats of the solution with a small paintbrush, let dry and you're good to go!
#4 |
Speakerholic
Clear nail polish. The stinky stuff.
EDIT: White glue with or without tissue is fine. The reason I suggest nail polish is that it dries very quickly. You're set to go before you've even washed your hands. |
| The 'Tater Patch | valveitude | Tubes / Valves | 17 | 13th July 2005 02:04 PM |
| Repair Torn Speaker? | james___51 | Multi-Way | 11 | 10th August 2004 10:21 PM |
| lol the patch.exe from micorsoft | karma | Everything Else | 1 | 2nd October 2003 05:46 PM |
| Page generated in 0.08603 seconds (69.68% PHP - 30.32% MySQL) with 10 queries |
