Old 9th December 2006, 03:52 PM   #81
GM is offline GM  United States
GM's Avatar
Originally posted by Cal Weldon
My throat opening is only 7.5".........
Greets!
FWIW, cabs with throat openings narrower than the 8" horn wall width are ideally only used with 800 Hz XOs, so unless you know when yours were made they may pre-date the introduction of the 511 in the mid '50s, especially if it has the added brace at the top of the throat that further reduces the low pass filter's area. By the time Altec began using 800 Hz XOs on the 511 loaded M.I. horn cabs circa '70, the 'bean counters' had long since dropped the option due to the A7-500 ~wiping out A7-8 sales, so for those folks with either a keen ear and/or response measuring equipment, there's some subtle sonic gains to be had by reducing the filter area when 811s are used with the larger throat cab.
Note that this applies only to Altec woofers listed for this cab or similar response mid-bass horn drivers since ones optimized for non-horn apps won't have the strong stepped response in the 500-1 kHz BW that you would be smoothing.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th December 2006, 05:09 PM   #82
GM's Avatar
Default Re: Re: Re: Altec 1803B
Originally posted by jeff mai
The benefits of big midrange horns are more than worth the hassle of interfacing a tweeter above 8kHz.
Greets!
While I agree with, and actively promote, 'BIB' where applicable, to maximize the performance benefits of a 300 Hz compression loaded multi-cell you'll need a much lower HF XO point, especially if the app is multi-channel. Also, ideally you'll need a larger horn unless a really steep XO and/or it's used in a very low power app since even the huge 1803 (http://www.wmeckle.com/BOYD/1803rca1.jpg) is no bigger than it absolutely had to be for acceptable performance in a PA app driven with a ~matching impedance amp and why there's no doubt in my mind this is why all the (relatively few) 1803 loaded cinema installs I saw when they were being dismantled used a 500 Hz XO, though I don't know if these were original or were swapped out when higher power and/or SS amps were installed.
GM
Old 10th December 2006, 12:37 AM   #83
Geoff H is offline Geoff H  Australia
Hey Ken,
'78 was a good year. My daughter (now my best mate) was born.
So was 76, for wine.
Geoff.
Old 10th December 2006, 01:18 AM   #84
jeff mai's Avatar
Default Altec 1803B
Only if you don't use EQ. And you'll face that issue with any CD horn even if much smaller.
What home app isn't very low power? FWIW, I used an active 24db/octave xover at 350-400Hz with my 1803B.
FYI - the RCA cabinet in that photo is one of the ones I owned and used with my 1803s. Boyd drove 1500 miles to Kansas to pick them up from me.
Old 14th December 2006, 09:30 PM   #85
Speakerholic
Cal Weldon's Avatar
I have now received my bolt on midranges so I started with this pole mount.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 14th December 2006, 09:32 PM   #86
Speakerholic
Cal Weldon's Avatar
Cut it, added some set screws.
Old 14th December 2006, 09:34 PM   #87
Speakerholic
Cal Weldon's Avatar
Resized the holes, added a cork gasket and mounted it.
Old 14th December 2006, 09:36 PM   #88
Speakerholic
Cal Weldon's Avatar
And now I have this.
Old 14th December 2006, 09:38 PM   #89
Speakerholic
Cal Weldon's Avatar
and from the front.
Old 14th December 2006, 09:43 PM   #90
Speakerholic
Cal Weldon's Avatar
First listening impressions are good. They continue to remind me they are a far field speaker so I'll have to wait till spring before I have a good listen from 50 or 100 feet. (15 - 30 m)
Fun project, used up some spare parts. All in all, very worth it.
Altec Lansing 604-8L? GeorgeJ Multi-Way 4 21st March 2004 01:35 AM
Page generated in 0.08906 seconds (70.94% PHP - 29.06% MySQL) with 11 queries
