Altec Lansing
Perhaps after rotating the driver 180º, you tilt back the enclosure about 30º (to contain the goop within the surround) and use a hair dryer to assist the migration. It may have off-gassed too much for that to work but it's worth a try. I have seen what happens when solvents get involved in inexperienced hands. Not going to say the drivers were ruined but he never took the grills off again.
hello,
I have two 421-8LF. Which voice of theater is suitable ? I seem to remember it was combined with mantaray horn.
thanks
Since these are musical instrument woofers with virtually no power handling [~1.27 mm], not the best choice for HIFI/HT apps, but these were the most common combinations [1233 - 1236]: http://www.lansingheritage.org/images/altec/catalogs/1978-mi/page04.jpg
http://www.lansingheritage.org/images/altec/catalogs/1978-mi/page05.jpg
Don't recall the Mantaray as an option with the 421 series, only seen them paired to the 300 & 800 series woofers, but you can use whatever horn/driver/XO combo you prefer and tweak to 'taste' in room.
GM
GM
The Stanley Screamers had a 421-8LF and Mantaray horn.
"fiberglass" found on drawing. But dust from fiberglass isn't it dangerous for loudspeakers ?
Can be if there's little/no airspace behind the driver, so loosely covering it with cheese cloth allows packing open weave insulation completely around it, though really dense cotton such as Denim Jeans needs to allow some room for it to 'breathe': Altec Heathkit legato 2-15 inch horn & driver
GM
