Old 29th November 2006, 12:07 PM   #1
Bigfootpete's Avatar
Default Multiple baffles and the effects
Does anyone know where I can find out the potential effect on the sound waves having multiple baffles will have?
Books websites etc...
I.e for a ported design where the sound is channeled like a transmission line - I know some of the effects of narrowing the baffle distance, but I'm just not sure of all the different effects.
Will I get a time delay effect? Will the sound be compressed and sound awful?
Or should I just try it and see?
I looked on the true audio website which has an article on reverb and echo but that didn't really help much.
Old 29th November 2006, 05:20 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Not quite sure what you're getting at. Could you restate the question?
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 29th November 2006, 05:53 PM   #3
leadbelly's Avatar
It sounds like you're calling the TL internals "multiple baffles". That's simply incorrect, and makes it hard to understand what you're really asking. Please clarify as badman says.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 30th November 2006, 11:22 AM   #4
Oh, sorry - my mistake - I thought they were called baffles (duh, now I know baffles are the foam inserts that fit around the magnet).
I meant the internal wood bracing...
I want to use mutiple braces to channel the sound, but am unsure of whether this will have a detrimental effect...especially if I narrow the gap between the braces towards the port.
Old 30th November 2006, 11:28 AM   #5
wigginjs's Avatar
To my knowledge the common use of the word baffle as it relates to loudspeaker design would be the exterior panel of a loudspeaker upon which the drivers are mounted.
The Four Chairs
DIY Home Theater
Old 30th November 2006, 05:41 PM   #6
Default I'm a noob but...
I think he's talking about those enclosures that are used with the really efficient fostex horns.
Old 30th November 2006, 10:05 PM   #7
leadbelly's Avatar
We are still not really sure what you're asking, if you could point us to some concrete examples that would help.
If you're suggesting, for example, that you have a design calling for a given box with an X diameter port Y inches long, but you also want to add internal braces with holes that are X diameter "channeling" the sound towards the port, then yes, those braces will impart audible resonances to the speaker and you will not get the same response.
Old 30th November 2006, 10:16 PM   #8
maxro is offline maxro  Canada
maxro's Avatar
If what you want is to figure out how to configure a transmission line, then I think you need to check out Martin King (MJK)'s mathcad worksheets at his website: quarterwave.com (IIRC).
Max
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt
Old 1st December 2006, 11:33 AM   #9
Maxro - if you have a look at my avatar you will see I have already built a TL.
My aim is to build my own design - but I would like to investigate what affects the bracing could have in advance before doing a trial and error.
Here's my design that I have so far - although I plan to add a bit more on the corners and use foam so there aren't any sharp edges.
Old 2nd December 2006, 01:54 AM   #10
maxro's Avatar
So, the question is what kind of transmission efficiency loss occurs to the back wave as it has to pass thru several 180 degree turns. I'm not the one to ask on this, but my understanding is that for bass frequencies (<100Hz?) it shouldn't really be an issue. At higher frequencies there will be increasing attenuation, which can only be a good thing.
I think with MJK's worksheets you would have to model it as though it were a sectioned straight TL. I beleive there's some mention in his user guides about bends and their effects.
Max
Baffles cut merlin2069er Multi-Way 0 4th November 2008 09:41 PM
Multiple subwoofer/multiple amp question boogs Subwoofers 5 13th November 2007 04:36 AM
New open baffles hurdy_gurdyman Multi-Way 3 26th September 2007 02:22 PM
Open Baffles :- ) brianon Multi-Way 17 3rd February 2004 08:13 PM
Page generated in 0.10047 seconds (80.56% PHP - 19.44% MySQL) with 11 queries
