Old 28th November 2006, 03:19 PM   #1
Klimon is offline Klimon  Belgium
Default Simple XO-question
What does a LC network (in series), mounted parallel with a woofer do? My guess would be a series notch filter where the resistance of the coil acts as resistor but allas it's definitely something else...
Here's my short story:
I'm trying to understand the low-pass filter of my ipl transmissionlines (6,5" alu cone woofers), the original design is a normal third order but with an extra coil in series with the parallel cap (= the weird combination I described above). The designer talks about a zobel filter in the crossover so I guess that must be it, no classical RC circuit to detect.
I later had the crossovers redesigned and that guy used a low-pass as follows: 1mH coil in +leg /// parallel with woofer: 0,56mH coil and 1,2ตF cap in series.... I've drawn a schematic below| Please disregard the จจจจ signs.
"+" ____coil________
จจจจจจจจจจจจจ|จจจจ|
จจจจจจจจจจจจcoilจจจ|
จจจจจจจจจจจจจ|จจจwoofer
จจจจจจจจจจจจcapจจ |
จจจจจจจจจจจจจ|จจจจ|
"-" __________|____|
Any hints are most welcome!!
Simon
Old 28th November 2006, 07:33 PM   #2
My math shows that the LC circuit resonates at 6.14 KHz, I assume to notch out a nasty peak in the woofer response.
Old 28th November 2006, 10:16 PM   #3
Hi Kent,
That makes sense! The woofer has nasty alu break-up peaks starting at around 6khz so that would be about right.
I hope that with a very low Fx frequency (1650hz) and 3rd order electrical filter the woofer will be rolled of plenty to make that and the following peaks inaudible. (about -35db?)..... Notch filters rob off too much of the soundstage magic imo.
Thanks alot!!!
Simon
Old 29th November 2006, 02:50 AM   #4
That sounds good.... I'm crossing a metal cone (Dayton RS 8") at 2 KHz and not hearing much cone breakup.
Good Luck,
Kent
Old 29th November 2006, 04:01 PM   #5
Thanks - same for you!!
Simon
A simple question from a simple man. inteificio Solid State 5 17th October 2005 03:00 PM
Simple Question zeonrider Solid State 2 3rd October 2005 10:56 PM
Simple question... Quattor Solid State 7 23rd June 2004 05:41 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
A Simple Question OMNIFEX Multi-Way 3 19th July 2003 08:11 PM
Page generated in 0.08001 seconds (74.33% PHP - 25.67% MySQL) with 10 queries
Copyright ฉ1999-2012 diyAudio
