How can I attenuate or reduce efficiency on a tweeter?
My tweeter is way too loud for the replacement drivers I got, and I'd love to subdue them a bit. I believe some arrangement with resistors may be possible, but I'm not sure what I'd be aiming for or what to do... |
#2 |
Custom Title
The easiest arrangement is an 'l-pad'. Madisound (www.madisound.com), parts express (www.partsexpress.com), solen (www.solen.ca) should have an option for you. Fostex sells a transformer based tweeter attenuator that I'd suspect to be better still, but it's more expensive. There would be a hookup diagram included with any of these.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
For the resistor l-pad bit, try this section of Rod Elliots' passive crossover article.
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#4 |
good info,in many cases a single resistor will do, but when keeping resistance low in the signalpath is of importance a series-parallel network is the choice...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
| High efficiency tweeter | JC951t | Full Range | 18 | 15th July 2009 04:56 PM |
| Attenuate tweeter level by 2 db | bastek | Multi-Way | 8 | 27th May 2008 10:08 PM |
| ESL tweeter efficiency | blu_line | Planars & Exotics | 10 | 23rd May 2007 12:45 PM |
| Looking for a high efficiency tweeter ... recommendations | paulspencer | Multi-Way | 0 | 13th May 2004 11:04 AM |
| Page generated in 0.08290 seconds (70.13% PHP - 29.87% MySQL) with 10 queries |
