Old 26th November 2006, 07:15 AM   #1
Send a message via AIM to Spasticteapot
Default Modelling a semi-open-baffle in WinISD for use with a sealed-box woofer?
Though I'm going to be mucking around with my current projects for a while yet, I figure I ought to learn how to use WinISD. However, I think that I can figure it out on my own; it's only when you try to add things that the program wasn't designed for that things get messy.
Does anyone know how to model an open-baffle speaker in WinISD? I was thinking about building a pair of speakers with 2 HiVi B3Ss and two Silver Flute 8" woofers. (The result should give me decent sound from 20khz down to 40 hz.)
Open baffle stuff, however, is harder: I want to model something like this:
http://www.audio-resolution.com/zhorn/f200a_1.jpg
The end result would have a big box behind it at the bottom - the enclosure for the woofer.
Any thoughts?
Old 27th November 2006, 02:11 PM   #2
WinISD only models bass alignments, nothing else, at these
low frequencies the shape of the cabinet does not matter.
Try the "edge" for modelling open baffles.
/sreten.
Old 27th November 2006, 09:49 PM   #3
/sreten.
The problem is that this is not a flat open baffle, so the EDGE is not of much use.
Eminence or P.Audio ? Open Baffle or Sealed Predator864 Multi-Way 0 23rd January 2009 11:51 AM
For modelling open baffle: MathCad v Excel rick57 Full Range 20 6th October 2006 08:32 AM
DIY Open baffle / Sealed woofer design preiter Multi-Way 11 25th August 2006 05:31 PM
Biamped Open baffle/Sealed Comments pls kestrel200 Multi-Way 4 23rd January 2005 02:33 PM
Huge sealed vs open baffle Flemming J P Multi-Way 13 27th April 2004 05:12 PM
Page generated in 0.07929 seconds (71.61% PHP - 28.39% MySQL) with 10 queries
