I have seen an Italian loudspeaker project that seems quite interesting :
http://www.audioplay.it I would like to know your opinion on it becouse I would build it (looking the good graphics). Thanks in advance: freccia |
#2 |
Hi Freccia,
Struggled with the text a little, but it looks like a tried & tested recipe brought up to date with contemporary drivers. OB FR augmented with enclosed sub (not sure if it said it was reflex). I'd have thought for the sake of simplicity, you might want to substitute the full range driver/super tweeter arrangement for a FR that'll do the job without the need for HF support - albeit at the possible expense of HF dispersion. That will give you a possible bi-amp configuration (with the right FR driver) where the full range open baffle unit can be wired directly to it's dedicated amp without any crossover components in the signal path. I think it's a neat design with (IMHO) real possibilities. Go for it!
Idlers ROCK! |
#3 |
Hi Jezz,
I will have in mind your considerations. Thanks: freccia |
| Interesting OB speaker project | ion | Multi-Way | 4 | 11th March 2008 12:52 AM |
| Interesting project for pre-amp remote control | bikedude | Chip Amps | 0 | 30th June 2006 06:31 AM |
| These look interesting for that SE project | georgehifi | Tubes / Valves | 2 | 1st August 2005 12:45 PM |
| An interesting weekend enclosure project. | nate | Multi-Way | 3 | 27th April 2005 03:19 PM |
| Ok guys here is an interesting project- | RyanC | Multi-Way | 8 | 12th June 2004 08:26 AM |
| Page generated in 0.07904 seconds (67.74% PHP - 32.26% MySQL) with 10 queries |
