Hi, Just finished building my 3 way speakers. The bass and midrange sound great, but the treble is a bit laid back. It could be a bit brighter. I added a L-Pad to the tweeters to drop the efficiency to match the Midrange. Do you think this might be the problem?
#2 |
diyAudio Chief Moderator
Shunt a 5,6 uf cap over the series Lpad resistor and tell us if you are content with the HF.
#3 |
Might be a number of things
Would help with a schematic of crossover and information of drivers, eventually a picture of speaker |
#4 |
Xover
#5 |
I am quite sure its phase related
First you should reverse polarity on midrange If thats not enough you should adjust capacitor on tweeter, which I am sure is too big |
#6 |
pic
#7 |
speakers
#8 |
Adjusting the L-pad will change the crossover freqency of the tweeter.
But it's best to adjust the L-pad balance by ear to get the tweeter energy in balance with the other drivers. You probably just added a couple of extra ohms resistance to the tweeter circuit. So you have reduced it's efficiency and possibly changed the crossover frequency quite a bit. You were at about 3-4 ohms before the L-pad. After the L-pad you are probably at around 6 ohms or so (guess). Try a smaller resistor value for the resistor in series. Of course it will change the crossover frequency a little but you've got to get the tweeter level set properly first. Then you can recalculate the cap value. Once you get the general balance set you can adjust the capacitor value taking into consideration the new resistance value. Work back and forth between optimizing the tweeter sound level with the L-pad and then recalulating the cap for the correct crossover frequency. After a couple of iterations you will have a good sounding blend that you like. |
| help treble | tadiam | Chip Amps | 4 | 26th August 2007 10:44 PM |
| No bass / No Treble But Bass And treble Help! | jleaman | Analog Line Level | 11 | 29th October 2005 06:45 AM |
| Best Treble Unit? | ShinOBIWAN | Multi-Way | 187 | 2nd May 2004 08:45 PM |
| Treble Control | palesha | Solid State | 5 | 30th April 2003 04:04 AM |
| Page generated in 0.10075 seconds (76.52% PHP - 23.48% MySQL) with 11 queries |
