In case you didn't know yet -
http://www.audua.com |
#2 |
Been to source forge ,there but no files loaded by admin yet.
#3 |
look in Code->CVS Browse
#4 |
You can "checkout" the project with CVS client
#5 | ||
Yes saw the files but to download Speaker workshop,one need to install CVS client to PC and register/create account with sourceforge.Essentially being tagged.I know it's a efficient management tool but a hassle.Just wanted to have a feel/look at the source code. Thanks. |
#6 | |
I have never used sourceforge but how else would you implement version control and check-in/out of files in the public domain ? |
#7 |
You don't need to register with sourceforge to download code, but it isn't exactly trivial if you've never used CVS and aren't used to command line stuff. You need to register to be able to check out files, though, IIRC.
I am so new to C++ that I am not sure If I can contribute, but it potentially interests me as an example of how an entire program is put together (even if it ends up being a bad example). I have MS C++ version 5, not sure if it will even compile in that environment. The place where Speaker Workshop really needs the most work, IMO, is in the user interface. These things kind of get an inertia, however, because the time to change it starts to be comparable to the time required to code it over, depending on how it was done.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#8 |
Wish List: Custom acoustic network simulator
I want to see a program or Speaker Workshop component with Akabak-style functionality combined with the SPICE-style editing of SW's crossover network feature. That is, the ability to connect acoustic resistances, masses, ducts, horns, and chambers together and simulate the entire electroacoustic network comprising the enclosure. This could provide breakthroughs in bass-reflex design as well as the design of mass-loaded horns, transmission lines, and other acoustic structures. |
#9 |
You don't need to use a command line CVS client. Tortoise CVS integrates with the windows shell; it's a pretty civilized interface.
http://www.tortoisecvs.org/ It will certainly save you some time trying to figure out how to check out the code. |
| Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 07:33 AM |
| Open Source, Open Architecture! | zenmasterbrian | Digital Source | 185 | 23rd February 2007 10:35 PM |
| Looking for Linux based (open source) speaker design software | Maxxarcade | Multi-Way | 3 | 17th January 2007 12:41 PM |
| Page generated in 0.10030 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
