Old 23rd November 2006, 10:48 PM   #1
Switch is offline Switch  United States
Send a message via AIM to Switch
Default MCM drivers--need advice
Hi all, i'm not exactly new to this world of audio, but i am new to designing speakers. I've done my homework, and picked out some drivers. The only remaining problem seems to be the lack of figures on the tweeter I've chosen, meaning that I've not been able to completely design the enclosure. (I'll be driving them with a tube amp, so 8 ohms is about as low an impedance as I want to go.)
I am planning on using either one or two Fullrangers per channel, and one of these tweeters per channel. I'll probably passivly cross them around 3.5Khz.
Keeping in mind that i am a college student, and thus live in confined spaces, can anyone reccomend a good cabnet design for a first time constructor?
Old 24th November 2006, 08:08 AM   #2
Dave R is offline Dave R  United States
Dave R's Avatar
Hi Switch,
The drivers you picked out look like they should provide a nice affordable solution to your "confined" college living.
Based on the specs, I think you might be surprised how much sound only one woofer and tweeter in each enclosure can provide.
Someone else may be more qualified to respond to your concern about the 8-ohm minimum load for your tube amp.
Looking at the smooth responses for both drivers, you might consider a series crossover. I'd recommend checking out Andy Graddon's website for info on series stuff.
Anyway, enclosure volume is basically dictated by the woofer. Given the specs for the MCM 55-1870, it looks like one would work well in an 8.0 Liter, vented enclosure, tuned to 53 Hz.
One solution would be to make the inside dimensions 7" wide X 11" high X 6.38" deep, with a 1.25" diameter X 3.25" long vent.
Hope this is a good start.
-Dave R
- Dave R
the 200% Norske
Old 25th November 2006, 07:01 AM   #3
Thanks, that sounds like it would make for a very nice compact pair of speakers, well suited to the environment i'm in.
A series crossover, eh? gonna have to look into that...
Your advice on some new (outdated) drivers retroman Multi-Way 5 23rd May 2009 09:20 AM
Need Advice for Choosing Fostex Drivers ezkcdude Full Range 5 12th November 2007 01:01 PM
Please give me some advice on what set of drivers for this box. azira Full Range 1 7th October 2006 10:52 PM
NEED ADVICE on drivers - > replace oem!! :) JinMTVT Car Audio 3 15th January 2006 08:06 AM
Designing my first crossover, 2-way, advice on drivers needed... nerd of nerds Multi-Way 10 10th November 2005 12:35 AM
Page generated in 0.07050 seconds (70.57% PHP - 29.43% MySQL) with 10 queries
