Old 23rd November 2006, 07:14 PM   #1
Nordic is offline Nordic  South Africa
Nordic's Avatar
Default What to do with this woofer.
I bought 2 drivers to try and repair an old set, but I am afraid, the drivers do not blend well with the tweeters, and I don't think it is working well with the bass refles boxes it is in now either.
http://www.tvm-valmez.cz/index.php?id=114&catit=102
Please help me find a usefull project for these.
I don't even know if these will work for a 2 way, maybe it should go into a 3 way... what do you think.
I also don't know if it is best suited for a sealed or vented box, or remotely what the best volume would be for an enclosure...
Been playing with winisd, but I simply just don't know enough... The woodwork is not a problem, I just have no idea what type or size enclosure to build.
ACOUSTICAL DATA
Rated noise power 1) 70 W
Short term maximum power 2) 140 W
Rated impedance 8 Ohm
Resonance frequency Fs 4) 34.2 Hz
Rated frequency range 30 - 3000 Hz
Sensitivity 3) 86 dB
TS PARAMETERS
Acquired by MLSSA 10.0.D
Effective piston area Sd 216 cm2
DC resistance of voice coil Re 7.4 Ohm
Mechanical Q factor Qms 5.22
Electrical Q factor Qes 0.88
Total Q factor Qts 0.75
Voice coil inductance Le 1.0
Equivalent volume Vas 71.5 l
Moving mass (including air load) Mms 19.9 g
Suspension compliance Cms 1087 uM/Newton
Force factor Bl 6.0 Tm
Maximum linear displacement Xmax 5) 6.4 mm peak to peak
MECHANICAL DATA
Voice coil carrier material aluminium
Voice coil diameter 25.4 mm
Winding height of voice coil 13 mm
Yoke diameter 25 mm
Air gap height 5 mm
Magnet external diameter 82 mm
Magnet internal diameter 32 mm
Magnet height 15 mm
Compensating magnet external diameter - mm
Compensating magnet internal diameter - mm
Compensating magnet height - mm
Weight 1.1 kg
TEST CONDITIONS
Sweep voltage 6 V
Frequency range 30 - 3000 Hz
Old 23rd November 2006, 07:37 PM   #2
Default TVM speakers
How the hell did you get TVM from Czech republik in CAPE TOWN? There is a forum dedicated to this drivers, but i dont know if you speak czech.anyway, try this http://www.amplion.wz.cz
find a project and when you find one and want to translate it, send me email at jdm1@zet.sk and i see what can i do.
Danny
Old 23rd November 2006, 07:43 PM   #3
Nordic's Avatar
Sadly no Czech, yep, I understood from the guy I bought it from he had to bring in 100 units...
I will have a look at your link... I guess anyone can understand pictures and diagrammes.
It is a very nice driver I have to say, and it was much cheaper than I expected.
THis one looks nice
http://www.amplion.wz.cz/vase-kritik1.htm
4 ohm or 8 ohm woofer in 2 way mmgando Multi-Way 0 4th December 2007 07:14 AM
What can I do with this woofer? Bricolo Multi-Way 5 1st April 2004 09:37 PM
diy sub-woofer takashi Subwoofers 3 19th August 2003 09:16 PM
the best mid-woofer? joz Multi-Way 4 19th March 2003 08:19 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Page generated in 0.07590 seconds (73.01% PHP - 26.99% MySQL) with 10 queries
