Hi, i have now read ALOT on crossovers and read about everything i could find out about the Hivi K1 tweeter and tangband W4-657SC. I made a simple 2nd order butterworth XO at 3000hz, including an attenuation circuit for the tweeter. the problem is that it's way to much treble, and its too weak in the mid. when playing with just the w4 connected the tone plays way up in the treble range. i can easily hear the tone (when using NCH tone generator) at frequencies up to 8-10khz!! is this normal? i'll guess this is why the treble is so dominating..?
is there anyone here with experience on these two drivers? who can help me out? I use the two drivers in a 2-way system, closed 2litre box. it's going to be used with a small subwoofer. Thanks in advance |
#2 | |
Your problem is likely wrong c/o values and not accounting for baffle step compensation. |
#3 |
yes i'lk guess that whats wrong. (allthough it seemed like something was completely wrong, like f.eks the Tb played fullrange or something. it lacked ALOT of low and mid frequencies, and it's supposed to play flat down to at least beneath 150hz. the treble was really dominating!)
sounded like there was not only someting wrong in between 2-4khz (XO at 3khz), but also everything beneath it. I have used an attenuation filter, so the tweeter should have the same sensitivity as the woofer. |
#4 |
After BSC the tweeter should have 4dB to 6dB less output than the nominal midrange sensitivity of the bass / midrange driver. Cookbook crossovers tend to assume the drivers are resistive, http://www.zaphaudio.com/tweetermishmash/fr.html not too hideous an assumption for the tweeter, but completely wrong for the mid/bass unit dure to its (lossy) inductance. This is compounded by the lack of BSC that should be applied to the bass mid driver. Read this thread, it may be useful : 3way XO help greatly appreciated! |
#5 |
what is BSC?
would you recommend me to use a zobel on the woofer? |
#6 |
baffle step compensation, a zobel is a lazy way of assuming correctness, generally not needed. |
#7 |
okay, thank you
but could someone please calculate the baffle step compensation for me? i do not have a clue how it's done! after what i've read different places, i think a 3rd order butterworth would do fine. and cross over at around 3khz. http://www.swanspeaker.com/product/htm/view.asp?id=30 http://www.tb-speaker.com/detail/1208_03/w4-657sc.htm the baffle will be about 24 x 24cm. tweeter in the upper right corner, and mid in the lower left corner. it would be very very helpful!! |
#8 |
diyAudio Chief Moderator
I have used that unit in this speaker and maybe you can just double the inductance and half the capacitance of my low pass part of the filter for one unit (8 Ohm). Its for 2kHz -6dB and the BSC involved is just right for a stereo pair in room. If you keep the baffle width the same its gonna be nearly spot on.
#9 |
a really nice person on pesupport.com designed a crossover for me
L1: 3.75 - 3.9 polypropylen L2: 6.5 - 4.7 + 2.2 = 6.9 L3: 7 - 6.8 can this work just fine or should i go for the expensive solution? |
#10 |
Hi, show us the crossover.......... ,
| HiVi B3S (UK, EU) | jimbo1968 | Swap Meet | 9 | 17th May 2007 03:31 PM |
| HiVi M5N or M4N | guru_jeff | Multi-Way | 0 | 8th October 2006 05:45 AM |
| Hivi Q1R | Phlim | Multi-Way | 2 | 21st July 2006 08:49 PM |
| zaphaudio hivi b3s crossover question... | jaygeorge1979 | Multi-Way | 23 | 26th January 2006 08:39 AM |
| Hivi Dmb-a | ypasco | Multi-Way | 0 | 18th November 2005 06:54 PM |
| Page generated in 0.12110 seconds (78.09% PHP - 21.91% MySQL) with 11 queries |
